Question about HP Compaq Evo Notebook N600c
Power supply 220v
I cannot find the voltage switch on my computer. moving to denmark and need to set up for 220v versus 110v in U.S.
    Scholar:
  • 116 Answers
Most laptops dont have that switch. You need a power adapter, to do the work for you. Or just get a generic adapter, to plug your power brick into.
Posted on Oct 11, 2007
I have an ELNA 3210 is 220v I live in Florida and need voltage transformer. from 220v to 110v for it and how many watts does it need? Thank you
From this document
http://edrenzi.com/Code/Trans%20(1p).pdf
the power is going to be the same as it was with 220V
However you need a step up transformer
if the supply voltage is 110V then the primary voltage needs to be 110V and the secondary voltage needs to be 220V dependant on your Elna needing 220V to run.
Does the ELna have a power rating plate at 220 V AC and if not does it have a current rating at 220V as power = voltage x current
so if it was 1 amp at 220v the power rating would be 220 Watts
When a transformer is involved the current on the primary coils of the transformer will half due to the 1:2 ratio of the transformer and will drag the same wattage as 220 V .
Another consideration is the frequency of the supply I am guessing the ELna is looking for 50 Hz and I think Florida will be on 60 Hz - not sure if this will be an issue in the ELNA but there are frequency adapters on the market to convert 60 hz to 50 hz if it is an issue.
You might be able to check the elna circuitry to see if it has a transformer inside it that you might be able to change to run at 110V down to whatever the elna runs on internally at its internal transformer secondary voltage.
Also check there is not a switch on the elna to switch from 220 v to 110v on the unit - not sure if it has this feature ?
Apr 18, 2018 | Audio Players & Recorders
What could happen with CD player switching on power supply 220v instead needed 110v?
Feeding it with twice the voltage it needs to work on?
In the best case, only a fuse has blown. Worst case? The whole power supply has had a to high voltage, before the fuse blew. All components will be aged and can give up in a few hours, after the fuse is replaced, or in a few months.
It also could be there are already some defect components in the player.
I wish you luck and hope only the fuse needs replacement.
May 25, 2014 | JVC Audio Players & Recorders
How to check weather computer is set to the correct voltage.
If it is present since not at Power Supplies have it, At the back of the computer, on the power supply, you should find a small switch. usually red color.
If you are in the US, you should have it on 110V.
If in europe, then you should have it 220V.
May 19, 2014 | Acer Aspire Z5600 PC Desktop
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
My system 110v mode i am connect 220v now not working my be what is the problem
your power supply is shorted.. make sure to connect your new power supply to the actual voltage .. 220V is for 220V input PSU.... if you connect your 110V PSU to 220V outlet... it will fry your power supply..
May 24, 2010 | Gigabyte GA-945GZM-S2 Motherboard
What is the specific power transformer (internal) i need to switch my logitech 230 speakers from 220v to 110v?
If the speakers are wanting 220V, will they work, at a diminished level, if you only supply 110V ?
Otherwise, you need a "step-up" transformer, which takes 110V input, and produces 220V as output.
Do the speakers have a "110V/220V" switch on them????
Apr 05, 2010 | Logitech X-230 Computer Speakers
I need a manual for the optical spectrum analyzer Anritsu MS9001B
Hi Jean, i have the same unit but at 110V, i need swich positions for 220V, if you can, please conntact with me at this email : nikig@langame.net, ill give you picture for 110V switches possition.
best regards.
NikiG
Feb 08, 2010 | Kenmore Elite HE4 Electric Dryer
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
HP Compaq Evo Notebook N600c Logo
48 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
