Question about Dishwashers
Just had bosch dishwasher installed by plumber but it is still not filling up with water. it works after we poor a pot of water in it.
Just had my bosch installed by a plumber. but i can't get it to fill with water. if we poor a pot of water in it, it starts to work. but there seems to be a problem with the hose. are we doing something wrong.
  • Samuel Charles Spriggs May 11, 2010
    Silly question, but did the plumber open all the valves when he finished the job? The water to the dishwasher could still be cutoff.
  • 423 Answers
Locate the hot water supply hose under the sink that connects and follow it over to where it will connect to the back of the dishwasher. Look for sharp bends in the hose. There should be a valve where the hose connects to the under-sink plumbing. Rotate that valve counter-clockwise to assure that it is open.
If the problem continues, the solenoid valve may have immediately failed. That valve is just behind where the hose connects to the dishwasher.
Good Luck!
Posted on May 08, 2009
I have just moved into a resale home{two years old} and the bosch dishwasher has a terrible odor what do i do?
Works for me, empty the dishwasher of any dishes, silverware, pot or pans, get (2) jars of "Tang" orange drink. Use (1) jar to fill the soap dispenser and poor the rest into the bottom of the dishwasher.
Run the dishwasher through a normal wash cycle with no heat/dryer time.
Run a second time if necessary. The orange juice acid will dissolve the build up in the dishwasher and rinse it away. It also smells good when your done.
For regular maintenance, repeat once every 3 months or so. It will not harm the dishwasher and will keep the interior components fresh and clean.
Good luck.
Oct 23, 2009 | Bosch Dishwashers
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jul 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I stupidly put washing up liquid in my very old Bosch SPS 21/24 as i had run out of dishwasher tablets - a few bubbles leaked out but all seemd fine and now it makes all the right noises but nothing...
Take a shop vac and remove all the water and suds.
No shop vac...use a towel or sponge.
Then use a pot to manually fill the dishwasher with cold water. Set it to wash a few seconds then go to pump out setting.
Re-fill with cold water and repeat this process until the normal sounds return and the washer is clear of suds.
HOT water will not work. It only makes the suds worse.
COLD water only.
Repeat repeat repeat ubtil clear.
May 14, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Jan 05, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwater not filling with water when switched on.
Hi nitwit2,
I'm Harvey the Master Plumber.
Your problem is: Dishwater not filling with water when switched on.
Electric on? Good. 9 times out of 10 it's a bad solenoid valve. It's under the d/w behind the kickplate on the left. I don't recomend this repair for the average homeowner. You might look in the Repair Directory for a repairman. If you're up to it, I find removing the d/w from the cabinet facilitates installation.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Bosch Dishwashers
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU3036UC not filling with water
u need more info first what happens when u shut the door and start a cycle
Nov 05, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher is not giving out water
Call a plumber to check your water pipe or you could twist the tap cap back and fort. Runs the dishwasher, if no water still. change FILL VALVE this is an electro-mechanical device that opens a valve to allow water to flow.
May also be called a WATER VALVE or WATER FILL VALVE.
If this does not solve the problem , you need to change the control board.
Does sugestion solve your problem? let me know.
Oct 09, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
