Question about Jacuzzi Home
Maxx jetted tubs error code co1
One side is working other is not.the serial no. for unit is 10010033
3 Suggested Answers
aquaspas
  • 6 Answers
SOURCE: MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Posted on Mar 22, 2009
uspartscente
  • 717 Answers
SOURCE: Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Posted on Feb 28, 2013
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
Control panel reading CO1..before reading CO1 it was beeping and convection symbol was on and 555degrees reading.
Hello. The C01 error code is telling you that there is a keypad malfunction. The following link is AWESOME for Dacor information on a wide spectrum of their products! Download the .PDF file and you've got a wealth of important info--error codes, settings, calibration procedures, etc. I hope I helped you!
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB0QFjAAahUKEwjNqKHA0oXIAhVDoYAKHZF7Bkk&url=https%3A%2F%2Fservice.dacor.com%2Fdocs%2FLinks%2F14.pdf&usg=AFQjCNFZry7xkBCe41bvln-sAUA0IGLkyQ&sig2=a4UCWFYBPuVGDpIXdLoQlQ&bvm=bv.103073922,d.eXY&cad=rja
Sep 20, 2015 | Dacor Kitchen Ranges
Where is serial numbering h&s mini maxx
generally serial numbers are on the back or underside of the unit. look for a number that starts S/N
Jan 06, 2014 | Mini Maxx Street Tuner for 2011-2013...
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
I have an LE code how can i reset
Try unplugging the unit for a few minutes. Then plug back in. If not try the Power button. I have an SE code (drainage problem) and my machine stops running altogether.
Sep 05, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Where can I buy just the brass trim on the jet for my whirlpool tub (aker)?
The trim for any brand whirlpool (w/p) tub must be ordered from that specific tub manufacturer. They will need to know exactly what your particular model is.
The model of your w/p tub, and serial number, is most often, but not always, located on the motor end of your unit but not on the motor itself. Access to this end of the tub, if installed to code, should get you the information you need, otherwise you are out of options'
Jun 03, 2010 | Whirlpool Royal A-909 Bathtub
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
I have a Maax Calla tub that the led is flashing E06 and it has been flashing for three days.
What does this control look like? Can you email us a photo of the control?
usually that error code is a water level problem.
Jan 10, 2009 | Maax Calla 6042 Bathtub - 101058-000
Tub pump
This may be due to clogged jets. Also, if this is a new application....the valves under the spa may not be in the up position to release the water to run into the pump and through to the jets. It may be a top side control issue as well. Check for error codes.
Sep 16, 2008 | Waterway 4 Hp 230 Volt 1 Speed Side...
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
