Question about Wega Coffee Makers & Espresso Machines
Machine not building pressure - Wega Coffee Makers & Espresso Machines
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Air pressure excessive
that's a valve that's in line with the internal plumbing..that's all that restricts that pressure, which can build quite high.
can you provide the exact model number, please?
Mar 02, 2008 | ECM Giotto Espresso Machine
My Oasis washer flooded the basement during a wash cycle? How do I fix this?
If the machine doesn't stop filling, it can be one of 2 problems. 1. the inlet valve has jammed open - water will continue to come thro when machine is switched off. 2. the pressure switch has failed. This is located at the top of the machine under the top cover and has a tube about 1/4 inch diameter attached to it, leading down to the drum. As water enters the drum, pressure builds up in this tube & operates the pressure switch turning off the inlet valve. Either the pressure switch is faulty or, more likely, the tube has a hole(maybe tiny) in it and is not allowing the pressure to build up. To test the switch, pull off the tube at the switch. Connect another similar piece of tubing to the switch about a foot long. Switch the machine to start filling. Blow down your new tube to the switch. The pressure you create should switch off the inlet valve while you keep the pressure up. If the water stops coming in, the switch is ok - suspect the tube. If the machine continues to fill, the switch is faulty.
Jun 23, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My compressor runs and builds pressure but, with nothing touched all of a sudden does not produce the same amount of pressure as before, it will not run my printing machine. What should I check?
Does the compressor have enough CFM to run the printing machine. Will the compressor build up pressure and shut off if you close the discharge valve at the tank. Your printing machine may simply be using to much air. If the above items are not the case you may have a faulty check valve in the receiver tank or valves going bad in the LP or HP heads. The valves may also simply have carbon build up or dirt of some type not allowing the valves to seat properly. I would start at the check valve. One way to check the check valve is to see if you have air blowing from the bleed off line at the pressure switch all the time. Another way to check is loosen the fitting at the High Pressure head an see if you have air blowing continously. Caution do not remove the fitting at the head completely. If the check valve is bad you will have high pressure air blowing until the receiver tank is drained.
Feb 23, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
I have a gasoline pressure washer. i connect machine the right way. try to start but machine only runs when trigger is pressed. stop pressing trigger machine shuts off. the water is flowing through the...
Not knowing exactly what type of pressure washer you have, most are equipped with an "unloader valve" so the pressure bypasses. If this is malfunctioning, the pressure will build up and bog the engine down.
Feb 11, 2011 | Garden
Building to much pressure getting to hot
Pressure stat bad and or boiler is limed up.You may want to check the pressure line from tank to pressure stat is clear.
Oct 17, 2010 | Grindmaster 1750 Espresso Machine
Frother builds up too much pressure and explodes off the machine
I had the same problem. All you need to do is take the steam nozzle apart and clean it. I tip can be cleand with a neadle. Just make sure you unblock the little side holes and make sure to thoroughly clean the little hole in the front. Over time the milk builds up in the nozzle, clogging up the "steam holes", so the preassure gets too big and the rubber attachments can't hold it any longer. Hope that helps.
Jun 05, 2009 | Jura Capresso F8 Espresso Machine
Tooo much pressure
If you remove the top panel on the machine there is a pressure stat on the right side, with 2 wire connections going to it. That P.stat could be damaged and needs to be replaced, or the pipe to the P.stat is clogged and it cannot read the boiler pressure.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
Water pressure
there is a screen in the inlet valve. it could be clogged. remove the hose from the inlet valve of the washing machine and look for a screen inside the inlet valve.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Whirlpool Washing Machines
Elektra S1C: Not enough pressure
you should look for pressure stat and look for calibration screw, than you turn it towards + to rise Little bit the temperature. Quoter of circle each test, until you get the desired temperature or pressure
Apr 06, 2008 | Elektra S1C Espresso Machine
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
