My LG Intellowasher 7kg front loader (model: WD14112FD) seems to keep getting stuck with 5min left of the washing cycle on the final spin.
My LG Intellowasher 7kg front loader (model: WM1285FHD) seems to keep getting stuck with 3min left of the washing cycle on the final spin
2 Suggested Answers
mikcaau
  • 3 Answers
SOURCE: LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Posted on Dec 29, 2012
Lg intellowasher 7kg wd8015c
OVER LOADING YOUR FRONTLOAD WILL DAMAGE CENTER CARRIER BEARING
Aug 17, 2013 | Washing Machines
I have a lg intellowasher 7kg wd-8015c (front loader), and its not spinning and the clothes come out wet. whats wrong and what parts will i need please
If the washer is not spinning you need to check on the motor, motor capacitor and the power from the program controller unit. If there is no power to the motor then the controller is a suspect.
Please check this link for tips: removing the motor:
Jun 23, 2012 | Washing Machines
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
Is there a filter in the LG INTELLOWASHER 7kg. If so where is it. The model is WD-8074FHB
its located on the bottom right of the machine front - open the flap and you will see a round filter base. ONLY OPEN THE filter during the last of the spin cycle to clean it, this is when most of the water has been pumped away. Opening it while the machine is off will cause a gush of water over the laundry floor.
Feb 08, 2010 | LG Washing Machines
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Sep 18, 2009 | Washing Machines
Sep 11, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
