Question about Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case
315 GB space available but can't add more data
I have a NexStar-3 external hard drive and it's worked great for me. However, I reached 150 GB full on it last week and found I couldn't add any more photos and music (what I usually archive here). I removed some files and this solved the problem. I'm back up to 150GB full again and am experiencing the same problem. My system shows that I still have 315 GB free on the drive and 465 GB total available, though. Any suggestions?
  • 696 Answers
Are the files that are on the drive all on the root C:\(or whatever letter it's using) or are they organized into folders such as Pictures/music/documents?
Second, what file format is the drive FAT32/NTFS(to find out right click on the drive in My Computer, left-click properties and in the window that pops up near the top you will see file system: _____
Answer back with that info and I will see what I can do to help you.
Chris
Posted on May 26, 2009
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
Files disappearing on external hard-drive (nexstar.3)
In this case you should use data recovery software to try recovering the files and data, provided those lost data are not fully overwrtten.
Be careful: Before your files are recovered, do not attempt to save more files to the external in case the original files are overwritten.
Feb 21, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
279GB free space in a Seagate 320GB will not take a 5GB pst file
First of all HI :)
The main problem you have is that the file system of your hard drive is FAT32 not NTFS. You need to change it to NTFS in order to work. Here is how.
>> Copy all your data (the 50+GB you used) on to another hard drive
>> Now from My Computer
>> RIGHT CLICK
>> CHOOSE FORMAT
>> CHOOSE NTFS FILING SYSTEM
>> instead of FAT32 and
>> give your hard drive a nice full FORMAT
This will take a while and WARNING you will LOSE all your DATA so DOUBLE CHECK BEFORE YOU START THAT YOU COPIED EVERYTHING.
Hope that this Fixya Helps you :)
Best Regards
(please take some time to rate solution thanks)
Jan 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
NexStar hard drive doesn't recognize its size
It may be crashed....use [Nucleus Kernel for FAT and NTFS ] software...
Oct 11, 2008 | Vantec NexStar-3 External 3.5inch...
Ps3
most likely your hard drive is full.
Go to Settings-System settings-System information. it should tell you free space on your hard drive from your total available space.
Your drive is probably filled with demos and saved data from previous games, maybe music or even dowloaded movies.
If still had the same issue after the restore there is a chance that your hard drive was swapped for a very small one. ckeck the system info first:
Free space : 12 GB/37 GB this is for a 40 gb
If that is the problem you need a different hard drive (SERIAL ata 5400 rpm ).. upgrading the hard is easy.. or even go with an external drive.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Firelite 60gb external hd
to clear all the unused data from your computer you need to do to things Disk defrag and Disk cleanup located
Programs> Accessories> System Tools if this is a externul drive with no Os on it Rigth click on the device icon select Format this will to erase Data bypassing your desk top bin
Jun 24, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar
Its normal, and is the signal showing the drive powering/spinning up and down. The drive spins at 7200 rpms, when you power it up or down, its switches onto the speed that best suits  what it's intended to do.
Oct 14, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case Logo
200 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
