Question about Nikon D80 Digital Camera with 18-200mm Lens
D80 Nikon - dark in viewfinder
When I look through my new-ish D80 Nikon everything is quite dark, kind of gray diffused, with area focus lines and squares showing. If I take a picture, it is way too bright. I have tried both my lenses...same trouble. There is a red warning light just before the picture is taken. What have I done? Is it broken? Is there a simple solution?
  • Anonymous May 13, 2009
    I have a NIKON D-40x with a 55-200 dx vr zoom... just started the other day... will take photos just fine, but very dark with the same stuff you are talking about... SAME.
    Driving me crazy, is my lens ruined?
    Novelist:
  • 181 Answers
What you see through the viewfinder is not exactly what you get in your picture. It is possible that your settings are just off in the camera. To make sure that this is the problem, set your settings to Auto and try again.
The red light before the picture is taken is a setting you can turn on to indicate that you have focused correctly. You can turn this off in the menu if this bothers you.
Lastly, I do not think your camera is broken. You just need to read your manual to make sure your settings are correct when you take a picture. Hope this helps.
NOTE: Please rate our help to keep this free service online
Posted on Jan 08, 2010
Perfectly good photos but image in view finder will not focus Nikon D80 camera
Try adjusting the viewfinder diopter. There's a little dial just to the right of the viewfinder. Turn it while looking through the viewfinder. You want to be looking at an unfocused view or a blank wall. Turn the dial until the focus brackets are sharp. Make sure you do this with your shooting eye.
Nov 16, 2010 | Nikon D50 Digital Camera
D80 Digital Camera with 18-135mm Lens: My nikon d80 will not auto focus when I push the s...
The r11 is in the lower right of the top LCD or view finder that is in the D80 manual page 36 it speaks about the buffer. The r with a number is how many shots the buffer at that moment can handle. It is not an error message. For auto focus issue is the lens in AF as well as the camera?
May 17, 2010 | Nikon D80 Digital Camera with 18-135mm...
Shutter release not responding
Hi tmclaughlin0, In the camera is in AF-S mode, the camera will not shoot until it acquires focus. Look on page 29 of the D80 manual.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
When the camera is turned on view window is not lit up viewing is dark and grey hard to focus but still takes a good picture?
Do you mean the viewfinder or the lcd-screen?
The Nikon D80 does not have a 'live-view' mode to watch the picture you're about to take on the LCD-screen. It's a semi-professional camera not to be used like a standard 'point-and-shoot' digital camera.
If it is the viewfinder that's out of focus, try adjusting the dial to the right of the viewfinder. It might also be that your internal mirror doesn't get powered (in this case you're unable to see the focus areas). In the last case you will have to get the camera serviced by Nikon.
Dec 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Dark Viewfinder and Slow Shutter Speed
At first it sounds like a faulty aperture blade that is stuck after your first press. However you mentioned that this happened in other lenses as well. Seems to me that there is a problem with your camera (e.g. mirror lockup problem or something else). Pls have it looked at by Nikon
Aug 13, 2009 | Nikon D80 Digital Camera
Nikon D80. It worked fine until recently (maybe after I took pictures during whale-watching in a heavy rain and camera got wet). Now the view in the viewfinder is kind of greyish and blurry. Focus area...
Seems like your problem on greyish/blurry viewfinder is caused by the camera getting water logged. Get your cam cleaned by Nikon.
The flashing red light usually happens if you have this indicator set in the camera. This may not necessarily be an error.. just a setting that you have put in place in your menu.
Jul 10, 2009 | Nikon D40x Digital Camera
Camera doesn't focus very well on dark subjects.
I think you have 2 problems at one time.
1 - I notice that your depth of field is very narrow, (your aperature is quite open) which hardly can focus the spot you want. try to increase the f/number like f/4 or above. the models face and there clothes toward your nikon D100 is almost the same distance, so they should be in the same focus range, but as I said witch big aperatures like f/2.8 of f/1.4 every inch count when it becames to focus.
2 - Set your camera in Single-focus (not Continous focus) en focus on the models face. then press halfway en keep it pressed. then you can compose a new position (still pressed halfway) and when the composition is good, then press it further to capture the photo.
Jul 02, 2009 | Opteka HD² for Nikon D80, D70s, D70, D50,...
Nikon D80 Digital Camera with 18-200mm Lens Logo
564 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
