Zanussi error CODe e34 - Washing Machines
Could anyone tell me what the Error Code E34 is referring please? Thanks
Maybe. Knowing what it is that is generating error code E34 would be good start. Need manufacturer and model number.
Oct 21, 2015 | Water Heaters
How can i resolve error in sam4s etr machine e34 ?
Is it an ER-5200m? They use error descriptions. Please provide model number.
Aug 10, 2015 | Samsung Sam4s ER-5200M Cash Register WITH...
E34 code what does this mean
Incongruence between level of electronic
pressure switch and level of anti-boiling
pressure switch 2 (duration of fault at least 60
seconds).
Cycle is blocked with door closed.
Could be: Hydraulic circuit of pressure switches; electronic
pressure switch; pressure switch; wiring between main PCB and electronic pressure switch; wiring between main PCB and safety pressure switch; and finally main PCB.
Dado
Oct 20, 2014 | Zanussi FJS1225W Front Load Washer
Frigidaire front loading washer error e34
Click on the link below to download a manual that will give you the information you need.
Click here
Hope this helps
Jan 06, 2014 | Frigidaire Washing Machines
What is E34 error?
web search canon error codes cursor through listings to find your error code and solution
Jan 23, 2013 | Canon NP 6050 Copier
What does error codes e34 and d65 mean on ariston boilers
You need to service the boiler and more likely to remove the restriction ring in flue, as only serving not always work or work only for short period, as boiler get older it is struggle to move exhaust gases out from burning chamber so it need good clean for fan, heat exchange , and there is restriction ring just befor L bow which need to remove so gases can flow better.
Jan 16, 2012 | Water Heaters
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
I have a Zanussi W/M ZWF1640 showing E34 fault codes in diagnostics mone. any clues?
Three things i would suggest on the zannuzi. Does water come into the drum at the beginning of the wash? Does the drum turn if asked to wash or spin? Does the drain motor disperse the water in the drum when supposed to. If motor does not turn, check the brushes. Sorry for being so vague, Zannuzi not common in S.Africa, but those are the common problems i have found while repairing the odd one.
Aug 03, 2010 | Washing Machines
We have a sharp cash register xe-a202 when we try to end a transaction by entering tend amount and pressing tl/ns button we get error code e34
Hi Wellsey,
The error "E34" means there is on overflow limitation error.
This means that the amount tendered is greater than how the machine is set-up to accept.
Try entering a smaller amount pressing TL/NS then enter the balance given or even break the amount up to three or four entries, the machine will show the outstanding amount to pay each time and deduct each entry from that balance.
Having done that and finalising the transaction you will then need to do the following to prevent this from happening again.
Refer to page 46 of your operators manual and set the parameters of job67 to those that suit the country that you are in.
Regards
Gavin.
Oct 10, 2008 | Sharp Office Equipment & Supplies
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
