Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
What kind of battery does a invacare prontoM91 use
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
http://www.invacare.com/doc_files/1125085.pdf
Regards
Chellakumar
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
Where will I find the reset button on my scooter ?
With this kind of issue, when you believe something is not right. Have the charger and the batteries checked out before buying new batteries.
May 11, 2014 | Invacare Lynx Lx-3 Scooter Model...
Wherecan I find information about an Invacare scooterFixing an Invacare scooter?
Hopefully you have kept the old set of batteries, I would get them tested plus have the charger tested also.
May 09, 2014 | Invacare Health & Beauty
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
Jun 20, 2010 | Invacare Supply Group Invacare Scooter...
Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
Jul 28, 2009 | Invacare Supply Group Invacare Scooter...
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
26 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
