Question about Braun Syncro 7526 Electric Shaver
Need to replace the base charger on my Braun 5000 series type 5736 (contour 5790)
Want to replace it
VtToolMan
  • 704 Answers
SOURCE: will not take charge
Yes, there is a rechargeable battery located in the shaver. To get inside, you have to remove the shaving head and then at the bottom, on either side where you plug in the charging cord, are 2 small plastic plugs that you have to remove with a sharp pick or thin knive blade.
Once you have the plugs out, you remove the screws and then you can separate the front and rear panels from the shaver body to get at the circuit board, which has the rechargeable battery soldered onto the PCB (printed circuit board).
To replace the battery, you have to unsolder it and reinstall a new one by soldering it back onto the board. If you're not comfortable doing this, or don't have the tools needed to undertake the repair, I can suggest Electric Shaver Service in Nebraska, they repair most shavers in a week or so and are very good at what they do. You can give them a call at 1-888-476-1785 or go to their website to get a repair request form, under "help".
http://www.electricshaverstore.com/
Hope you find this Very Helpful and best regards!
Posted on Aug 20, 2009
VtToolMan
  • 704 Answers
SOURCE: My former razor, Braun 5414 would take 110-240AC
According to the Braun manual for your 5414 Contour, the specs for charging are printed on the electric shaver cord plug. (it's REALLY small print, so I'd get a magnifying lens to look at it!)
There isn't anything in the manual about the multiple voltage for charging the shaver, so I'd have to defer to the Braun (Gillette/Proctor & Gamble) customer service folks to make absolutely certain of what can and can't be used as a charging voltage before trying.
Here's a link to your manual, in case you're missing yours.
http://www.retrevo.com/d/ds/progress?doc=9142c4ae65df1746d12fc67fdc01df52
You can ALSO reach the Braun Customer Service folks by calling them at 1-800-BRAUN 11 (1-800-272-8611)
I hope you find this Very Helpful and best regards!
Posted on Oct 10, 2009
Cytherian
  • 124 Answers
SOURCE: need replacement battery for braun Model number 5000-type 5724
You can certainly go to shaveroutlet.com and pay $9.99 per cell, or go to a place like onlybatteries.com and pay $3.69 per cell with a higher mAh (2200 vs. 1650, which means a longer run time).
Keep in mind that if you're not skilled at soldering, you'll have to buy the batteries plus circuit board. This will end up costing you nearly $40. In that case, you're probably better off going with a new shaver (get a new old stock 8000 series shaver for around $50 on average, at "that auction site"). :-)
Posted on Oct 22, 2009
brector3
  • 1621 Answers
SOURCE: My braun Contour 5790 does not charge in either
It my be the batteries but they usually go bad very gradually and you should still be able to use it from the cord. It sounds more like a problem with the circuit board.
I suggest that you first find out if it can be covered under warranty. You can call an authorized service center at 847-869-7755. They can tell by the date code on it when it was made. If it was made less than 2 years ago. you shouldn't need your receipt.
Posted on Jan 26, 2010
Testimonial: "Thanks for the help. I will call the telephone number. Rich"
  • 185 Answers
SOURCE: how do you get the braun 5790 razor apart?
Try this page,. It should be helpful.
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters.html?cat=135
Good luck
Posted on Jan 30, 2010
Where do i buy repolacement batteries for my braun contour 5790 electric shaver?
Use this link: http://www.braun.com/us/male-grooming/maintenance.html
Jul 15, 2014 | Health & Beauty
Braun contour 5790 battery replacement
try this link: http://www.braun.com/us/male-grooming/maintenance.html
Jul 15, 2014 | Braun Flex XP II 5790 Electric Shaver
Braun 7526 not pumping solution
The pump is no longer working. You will need to replace the unit. Replacement can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun/braun-7000-series-syncro-clean-charge-base-p-122.html
Mar 10, 2013 | Health & Beauty
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
My braun Contour 5790 does not charge in either the cleaning stand or by the cord alone. Can you help me in this dilema?
Jan 25, 2010 | Braun Health & Beauty
My former razor, Braun 5414 would take 110-240AC as well as 12 DC. Now have Contour 5790, and want to know if itcan also use12 volt DC.
Oct 06, 2009 | Braun Health & Beauty
Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
Mar 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
22 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
