Question about Bazooka BTA10100 Car Subwoofer
''12'' kicker square rubber broken
How do i fix it? its on the corner and it ripped by it self pounding do i need to replace all the rubber or get a new one.
  • 709 Answers
  • Greg Stokes
    Greg Stokes Oct 11, 2007
    HI Gmaninfinite,
    The URL above looks like a great possbile solution for your problem. I hope it helps you...
SOURCE:
How many rubber sensor has self-balancing scooter replacement frame?
It's a complete set for self-balancing scooter replacement frame. The set has 4 rubber sensors attached to the frame, 6 mm hex wrench for removing motor wheels and 2 metal squares.Click here for full review of self-balancing scooter replacement frame Best Hardware Replacements For Scooters And Other Rides Top Hardware
Jun 04, 2018 | Cars & Trucks
I have a 15" kicker that's square and the coil is stuck its not blowed how do I clean it
U don't - if abused the insulation on speaker windings will expand and wedge the voice coil in the magnet gap.
Only fix is to replace entire driver - sorry.
Feb 28, 2015 | Kicker Car Audio & Video
How do you take the cvr kicker apart
are you sure that you are capable of replacing the rubber ring if you don't even know how to take the speaker apart? I am Not sure that that's a challenge you want to accept.
Mar 11, 2012 | Kicker Comp CVR 12 x 12 Car Subwoofer
Need rubber lip and diaphram for 10
junk it upgrade to a mtx thunder square 8500 im just waitin to blow my L7 10 but its taking like 8 years,,, hahaha
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 09, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Rip fence is out of alignment..what do I need to do?
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Jan 14, 2011 | Saws
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Have 2 12 inch kicker cvrs the foam or rubber outside ring has a whole how do i fix itcan i buy the whole rubber ring?
you cant buy just the ring. you have to recone the woofer. you may be able to try some home remedys for repair but if the woofers are in a sealed box they are under tremendous pressure and glue may not hold. how large is the hole?
Feb 13, 2010 | Kicker CVR12 Car Subwoofer
I have a 12" kicker thats ripped.
There are repair kits to fix this. One place you might want to check out is www.newfoam.com
Nov 18, 2009 | Car Audio & Video
Cracked Rubber
what i would do is:
super glue the cracks, allow to dry and then use a silicone lubricant spray and let sit for about 10 min then wipe clean. silicone spray can slightly restore the rubber/foam
Mar 16, 2009 | Car Audio & Video
Bazooka BTA10100 Car Subwoofer Logo
219 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Martin van der...
Martin van der...
Level 1 Expert
Dalynn Turner
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
