Question about Garden
I have a Blizzard King electric snow thrower model DB5022B that needs a new chute. Where can I get one?
Need to find a parts list or phone number for this snow thrower so I can replace the chute
bbreton
  • 437 Answers
SOURCE: Electric start turns over, but engine doesn't
If gas has been sitting in the carburetor since last season, The carburetor will need to be cleaned out and rebuilt. Some ports may be clogged up that allow gas to flow.
HTH
Good Day.
Posted on Oct 30, 2009
rwvanlue
  • 486 Answers
SOURCE: I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 16, 2009
miket756
  • 2702 Answers
SOURCE: Removed clip from axel, but wheel won't come off.
you never sead if its the front or rear axel,,,but i gess its the frount one your talking about,,,if so its just stuck to the shaft maybe there is a slight burr on the end of the axel shaft,witch needs to be removed first or its stuck on the drive kye way give it a tap with a wooden mallet on the back of the rim it may jar it off,
Posted on Nov 21, 2009
  • 61 Answers
SOURCE: I need parts manual for MTD Snow King Snowblower
on the internet try
mtd.com/manuals
Posted on May 29, 2010
SOURCE: Just purchased a Poulan Pro Snow Thrower and on
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Posted on Nov 30, 2010
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Tip
Snow throwers
Just returned from the parts store, they had sold out of drive belts for the auger drive on snow throwers... figured I could help out here;
Wet snow is heavy, duh right? Before you run your snow thrower disconnect the spark plug, for safety. Check the chute, and sand any loose paint rust etc. you want a smooth chute.. paint if needed, let dry 24 hours before use, spray with silicon lube spray, this will loessen the stress on your auger belt and hopefully keep your machine running all season. Good luck!
on Feb 28, 2010 | Air Purifiers
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
Huskee snow thrower spout clogs
Before use spray chute/housing with Pam or WD-40
Also push unit faster to move snow through easier.
Feb 24, 2015 | Huskee 21 in. Single-Stage Snow Thrower
How do you rewind a chute turn cable for a Craftsmen Snow Thrower 1150?
Need to know what cable you are asking about. Is it the starting cord for pull starting the engine or one of the auger or drive control cables ??
Can you post a picture ??
May 18, 2014 | Garden
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
Need a parts manual broken chute control cable
I tried searspartsdirect and they don't show that model. Not sure if it's the right number as it doesn't look like their number. Usually their model numbers have three numbers a period and some more numbers.
Does the machine says Sears on it ??
How new is it ?? Is it gas or electric ??
Jan 10, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
246 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
