Question about Protege 5 pipe, by - pass. 1500 - cooling system 2000CC
Mazda astina 1999 1800se
Turns over but no visible spark
    Sergeant:
  • 294 Answers
Check your coil connections. Possible loose connection on the input side. Either way it's off to Autozone next with the coil(s) in hand to see if maybe there's an internal short.
Posted on Nov 27, 2013
Cannot find spark plugs in 2003 323 1.8 litre mazda astina
If you follow the wires to the top of the engine from the distributor, they are under the boots when you remove them. Plugs are about 4-6" down inside. f2c5d262-e131-42d7-8496-0946d38b78c6.jpg
Apr 20, 2014 | 2003 Mazda 323
Mazda v6 timing marks astina 1994
There should be little groves on the crank pully 4 or 5 marks
Nov 09, 2013 | 1989 Mazda 323
`993 MAZDA ASTINA WONT START
fuel pump / ignition coil if no spark
Feb 16, 2013 | Mazda 323 Cars & Trucks
My 1994 mazda 323 astina automatic revvs high and low. what's the problem
When does is rev high and low? If it does this at idle check for a vacuum leak or maybe a blocked airflow
Jan 12, 2013 | 1994 Mazda 323
2000 model mazda 323 astina cylinder head bolt torque specs
Three stages with new bolts (a must), 1st 60 pounds, then 70 pounds then final torque is 80 FT Pounds.
Feb 16, 2012 | Mazda 323 Cars & Trucks
My mazda astina 323 wont start. it is getting fuel and wants to start but wont???
Are you getting spark to the plugs? If not, the iginition coil or ignition module may be bad
Nov 24, 2010 | 1991 Mazda 323
Mazda astina pop up lights wont go back down
Try to check if there is something stuck to the motor of the pop-up lights mechanism. You can see it below the fenders. The fender liner should be removed.
May 27, 2009 | 1990 Mazda 323
1989 mazda astina 323 5 spd manual clutch fluid??
open your bonnet check to see @ gearbox if the-res is cable, or a cylinder, the cable is Usualy visible on the top of the gearbox if theres a cable theres no clutch flu-ed needed. Note that your gearbox uses oil. Usualy on older models like 1989 the use a clutch cable no flu-ed needed
Jan 03, 2009 | 1989 Mazda 323
Protege 5 pipe, by - pass. 1500 - cooling system 2000CC Logo
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
JOHN LAPIER
Gary Nitowski
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
