Question about Sylvania 6842PE TV
Part disclored picture
Our tv dropped about a 1 to 1 1/2  feet to the floor, and the picture is still there except on the left top corner going almost down to the bottom left corner,is green and another part is red,,,,,,,the people are turning colors on that side etc................could i repair it, or take it to a repairman,,,,,,,,or is it not worth the money and can go buy another cheaper than fixing it?thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As it has fallen on the floor
due to that its deflection coil position might  have  changed a little.
due to that its left corner has gone down.
deflection coil has convergence magnet on it so due to that there is change in color also.
please call tech to re position of deflection coil every thing will be fine as it was.
as per buying another it is up to you.
hope this will help.
Posted on Oct 11, 2007
SOURCE:
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
I accidently dropped my HP G71-340US notebook laptop approximately 2 feet hitting the hardwood floor. It was closed and hit the front corner. It sill works fine except all pictures have a grainy, swirling...
you have probably damaged the screen itself, try using it connected to an external monitor, if you have a good picture then your screen needs replacing
Apr 09, 2011 | HP Computers & Internet
Cant get the machine to balance service guy comes out with my dad at my house who is 70 years old and service guy tells him nothing is wrong . i leveled it out and it shakes the house and says uneven load...
Hi from retired Englishman in SW FRance @ 16:49 Sat afternoon- nothing on TV!
As the service guy says there is nothing wrong with the machine it must be that it is STILL not absolutely balanced.
Really rock it from each corner. If it rocks, even a little, from the right hand front corner then it is the foot underneath that corner which need to be adjusted downwards until it is TIGHT onto the floor then locked by the locking nut so that it cannot vibrate loose. If not this corner then the left hand side need adjusting.
The feet DO need to be very firmly on the floor- honest!
Best of luck,
John C
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
While on rinse cycle. the machine make a loud of noise, the whole machine shake alot. i replace all the 3 spring, and one spring on the back. and notice there is 2 pin that drop. so i re scure the pin. but...
I had the same problem. It was a combination of unbalanced loads and the machine was not level. I used a torpedo level I bought at Lowes to check the level of the machine. First, standing in front of the machine, put the level on the front edge of the machine top. Measure left to right and using a wrench adjust the screw feet on the bottom front of the machine until you reach level. Then standing in front of the machine, grab the two back corners of the machine console body (do not use the control panel for this as you will break it loose from the body). pulling up and forward, rotate the machine so that the back feet are lifted off the floor, while the front feet are still making contact with the floor. This allows the back feet to automatically level the machine. Using the level check from front to back on the left and right top of the machine body to ensure level is reached. Repeat the entire process until you reach an acceptable level condition on the washer. Note: All level measurements must be made on a flat surface of the machine.
Jan 19, 2011 | Whirlpool Washing Machines
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Oct 17, 2007 | Toshiba 36AF43 36" TV
Sylvania 6842PE TV Logo
80 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
