Question about Welding Tools
WIRE FEED BUT NO ARC
Wire feeds but no arc
    Problem Solver:
  • 9 Answers
Turn off welder, unplug and press trigger to discharge any possible stored juice. Then, open side door and check the ground cable where it connects inside, it sounds like either ground or the hot is off. Once you determine those are both securely attached, close door, plug in power on, attach ground clamp to test piece off metal and try it again. Let me know if this helps! Thanks:)
Posted on Jun 17, 2009
My miller 175 wire feed does not feed wire at low number settings
Usually, the drive motor voltage is derived from the weld voltage, so if you lose, the weld voltage, the motor will not turn. Feed some wire out in a setting that works, then switch to one that doesn't feed, and see if the wire will arc. If you have a voltmeter, check for DC voltage at the polarity changover. Might be a bad voltage range switch.
Mar 30, 2017 | Miller Welding Tools
Mechpro 100amp mig welder
It won't arc without wire in it. If the motor runs then there may not be enough tension on the feeder wheel to push the wire thru. If you had a bad kink in the inner liner it will not feed. The trigger switch in the handle applies arc voltage to the copper nozzle. It may be bad or have a broken wire.
Dec 15, 2013 | Welding Tools
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
My Hobart 175 Handler wire feed stops shortly after the arc is struck. Recovers in about 20 seconds. Motor protection ckt is probably doing it. No restriction in feed cable or gun, wire moves smoothly....
Yes sounds like it is "Detecting" a "Fault" condition and shutting down the Arc for safety, then it recovers, and it repeats, I think, you should Check, your Earth leads, Connections, and Overcurrent Protection Threshold if there is a control. Check power is going to the feed motor at time of arc, and if it is still getting enough or if it, the voltage to it,"Sags" under load...In this case it is a power supply problem.
Mar 10, 2010 | Welding Tools
Wire doesn't feed and I cannot get an arc
Fist look and check the contact tip. ensure the tip is the correct size for the wire being used as well as the wire feed rollers. the contact tip is were the wire collects the power,
If it's only 3 day's old send it back, dont star strippin it down or you Garantee will be made invalid.
ken
Jan 09, 2010 | Hobart Handler 125 Ez
No arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
Apr 04, 2009 | Welding Tools
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
274 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
