Question about Refrigerators
What is cf size of model 78902891 - Refrigerators
Err cf
Try formatting the CF card in your computer and if it can be done successfully, return to the camera and try to format it in the camera. If not, then the card is bad or it is too large for the camera to read. Some older cameras have limits to the sizes of cards they can read.
Sep 27, 2014 | Canon Rebel XT / EOS 350D Digital Camera
JVM1331WW 002 What is the cu. ft.?
The "13" in the model number means it's a 1.3 CF model.
GE Customer Service (here) can tell you if they have a "drop-in replacement" model.
Apr 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I require LAN drivers for my panasonic cf-29
This depends on the specific model number:
CF-29C/D -- Realtek RTL8139DL 10/100
CF-29E/F -- Realtek RTL8139DL 10/100
CF-29H/J -- Realtek RTL8139DL 10/100
CF-29L/M -- Marvel Yukon 88E8053 10/100/1000
CF-29N/P -- Marvel Yukon 88E8053 10/100/1000
Dec 28, 2010 | Panasonic Toughbook CF-29 Notebook
Older VHS-C Palmcorder Memory cards size recognition
Dear Sir,
Yes all noted on your SD/CF card question, well this was a very good question for me simply because I too have had this same problem with my own Sony Digital 340 movie camera.
My camera come with a 128 mb SD card, and like a fool I went last week and bought a 2 g card, and my camera just cannot see it let alone use it, and I now find that camera's before 2004 cannot see any g cards, and like me you are stuck with small max of 128 m because the camera hard-ware is old tec stuff, sad I think my friend, but that's it.
Take care,
from
David
Jun 03, 2010 | Panasonic Palmcorder PV-L452 Camcorder
I WANT TO CHANGE MY HDD 80GB AND 512 MB RAM INSTEAD OF 6GM AND 128 MB RAM IN PANASONIC MODEL NO. IS : CF-27EJ6K3EE SERIAL NO. IS : 0 JYAA 65627 IMEI NO. IS : 500063080856270
Go to Crucial or Viking or any memory company on the web, type in your model number, and they will provide the proper memory module advice. You can remove the cover from the HDD on the bottom of the toughbook, and inspect the current disk to determine if it is SATA or not. I would check the manufacturer and series (model) and see if they had a larger in the same series. It will be labeled if it is SATA or EIDE, and you would get the same in a larger internal size.
tom
Dec 20, 2009 | Panasonic Toughbook CF-27 Notebook
Can this Olympus C5050Z works with Sandisk CF Ultra 4GB 30MB/s? I tried to insert it, and always gets card error message, although I can use the card in my notebook.
Your camera was designed to be fully CF compliant, but it was designed long before 4GB cards were available so your problem is likely to be that the camera cannot handle a card of that large a capacity.
I've checked the Olympus servicing manual but unfortunately it doesn't state a maximum CF capacity and there have been no relevant firmware updates to extend CF compatibility.
When your camera was released back in 2003 the largest capacity CF card was 1GB so I suggest that you don't go above that size. You'll also be wasting your money on any more than a regular Sandisk Ultra as the camera cannot take advantage of the faster data transfer rates of later cards, I'm not even certain that it can utilise the speed advantage of an Ultra over a really basic model, but it won't cause the camera to throw it's toys out of the pram either.
I hope that you've found my reply to be of use and ask in return only that you return the goodwill and rate my answer.
Nov 23, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
What size in inches is a A85 memory card. I put
The A85 uses a Type 1 Compact Flash (CF) card. If you're trying to put an SD card into the slot, it won't work. Using a strong light, check carefully in the card slot that you haven't bent any pins before inserting a CF card.
Aug 26, 2009 | Canon PowerShot A85 Digital Camera
Upgrade hard drive in panasonic toughbook cf-50: Any Disk?
its not brand specific rather the size ant 2.5 size whatever capcity will work for this laptop, Thanks
Rulds2008
Jun 26, 2009 | Computers & Internet
PowerShot G1 + cf card
The Canon G1 was my first digital camera, years ago. When this camera was sold it came with a 16 Mb CF card. The manual refers to CF card sizes from 8 Mb up to 128 Mb and the number of photos you can take with each size card. However, I bought my camera together with a 1GB "micro drive" (tiny hard drive in a CF card format) and although it wasn't "supported" by Canon, it worked fine. I also used a regular 1GB CF card in it (after I lost the microdrive card). If you want to use a card larger than 1GB with this camera, test/borrow a card to make sure it works before you buy one. Camera stores always have a variety of cards (used to demonstrate the cameras they are selling) that you can put in your camera and test before you decide which card to buy.
Dec 15, 2008 | Canon PowerShot G1 Digital Camera
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
