Question about Refrigerators
Fridge troubleshooting I have a Vitrifrigo C 130l 12/24Vcc frifge in my motorhome. I have noticed that the fridge motor is runnung contunously. It trips out then trips straight back in again. It did not do this previously. Can you advise please
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Posted on Nov 27, 2013
2 Suggested Answers
SOURCE: Vitrifrigo 3 ways fridge in campervan not working on batteries
You can fit a relay connected through the vehicle ignition that will prevent the fridge running on 12V unless the motor is running, this way you will not drain the battery.
Posted on Jan 26, 2009
My Vitrifrigo DP2600 fridge now gets very hot along the front divide between the fridge and freezer. What could cause this? How can it be fixed?
Seems like your self defrost mechanism is fubar. Check the defrost element and make sure that it is not open and that the timer is working. I parts needed go here Search Over 2 1 Million Appliance Parts
Sep 11, 2017 | Frost Refrigerators
We don't know how to hold down our vitrifrigo fridge in our motorhome. There were no instructions with the fridge.Its a C130 I.
talk with a caravan service center but you can remove the rubber feet and front adjuster bolts and use those points to bolt the fridge to the floor of the motor home
advice from people who install fridges to vans and motor homes would be a good place to start
May 06, 2017 | Refrigerators
Ther refrigerator side is cold and there is ice in the freezer side. I've raised the temperature on both sides but the units keeps runnung and never stops.
There is ice on the freezer fan motor. If it is not ruined, simply turning the fridge off for a day and leaving the doors open might clear out the blockage and the fan may start working again. If not, then you need a new fan assy. If you are not really handy on repairing these kinds of things, prepare to spend a few hundred to have it fixed by a qualified repairman. When you shut the fridge off, make sure you put your food in another fridge or cooler with some ice in it... just sayin's all.
Nov 24, 2014 | Refrigerators
Hi, i have water leaking out of the plastic cover between the frifge and freezer part - quite a lot of water
clean out drain pipe with very thin wire drop of clorine bleach do not EVER) bleach interior of fridge/freezers
Feb 08, 2010 | Refrigerators
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
We just bought a 1978 ford sportsman motorhome. It runs great the generator works but we cant get the fridge to work. It was winterized I dont think its broken but Im just not sure what Im doing wrong.
the fridge in my camper wont work on 110V either , and I have been told to replace the element that heats the (amonia) coolant. I never use the 110V anyways so i havn't fixed it. Fridge works fine on Gas , but it takes quite a while for these evaporative type of fridge to produce noticable cold. Very much a different system that your household fridge.
May 02, 2009 | Ford Explorer Sport Cars & Trucks
Jan 18, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
