Question about LG CHOCOLATE VX8500 Cellular Phone
Lg 8500 lost keypad code
My daughter locked her phone and can not recall the code. No it is not the last four of her number. It was a "random" four digits. Is there a way to recover the lock code?
  • lostcode Oct 11, 2007
    Disregard; I managed to get the phone to dial *228 and just re programed the phone over the air. This reset the password.
  • Anonymous Jan 09, 2009
    thank you man! worked perfectly and now my phone is fixed... how on earth did you figure that out?!?!
Caal verizon asked them if they can help
Posted on Oct 10, 2007
SOURCE:
How do i unlock my lg 8600 flip
  • Flip open the phone so the keypad is exposed and press any button to wake the phone up from sleep mode.
  • 2 Enter the four digit unlock code using the phone's keypad. The default code is the last four digits of your cell phone number.
  • 3 Press the "OK" button to submit the code and unlock the phone.
Forgotten Code
  • 1 Turn the phone over and remove the battery cover and battery. Press down on the upper plastic edge of the cover and slide it in a downwards motion. The plastic cover will give way to the battery which can be pulled out of the phone.
  • 2 Locate the sticker on the phone hidden behind the battery. Write down the last four digits of the ESN DEC number.
  • 3 Replace the battery and battery cover and turn the phone on by pressing and holding down the "Power" button.
  • 4 Flip open the phone so the keypad is exposed.
  • 5 Enter the last four digits of the ESN DEC number. Press the "OK" button to submit the code and unlock the phone.
Power the phone on and select the "OK" button. This will trigger the phone to ask for the password.
  • 2 Press "OK." Sometimes this is simply all it requires. If not, move on.
  • 3 Enter the last four digits of the phone's number. If this doesn't work, continue to the next step.
  • 4 Enter "#4357" or "*4357." "4357" stands for "LOCK" on a traditional telephone's alphabetic keypad translation. This is the default unlock code for certain LG telephones.
  • Dec 06, 2011 | LG Cell Phones
    Tip
    LG RUMOR lock code
    if your phone is locked and you dont know the lock code, enter the last four digits of your wireless number. my daughter locked her's by pressing and holding the #key. she freaked because she didnt know the lock code. i entered the last four and unlocked phone.
    on Jan 09, 2010 | Cell Phones
    When turn on unlock code comes up
    First if phone is lock dial *228 and then press 1. That reset your code for last four digit of your cell #
    (phone will reset ,no any data will be lost)
    If you do not know a cell # and phone is still lock then press .
    #4357*4357.and you can see phone number that's your lock code last four digit... That's for LG VX8500 (VERIZON)
    (or)
    Here's good news and bad news. The good news is that you might well have forgotten that the default password on the phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open
    for manual copy this link to your address bar and click ENTER-->http://docs.phonedog.com/lg-vx-8500-chocolate-manual-3959.pdf
    If nothing works , then you have to buy the unlock code here-->http://www.foneszone.co.uk/unlock/how_to/LG/VX8500.php
    Thanks for rating good luck
    Feb 07, 2011 | LG CHOCOLATE VX8500 Cellular Phone
    My daughter locked her phone and we forgot the pass code. I can we unlock the phone for use? Chocolate touch!
    there's a few ways/options
    -the last four digits of the phones number
    -the billing code password
    -the voicemail password
    Mar 10, 2010 | LG Incite Cell Phone
    I have a 13 year old daughter, andhave taken her phone away from her. She locked the phone, and I need to see what is on it. How can I unlock the phone? It is a LG VX8300. Thanks
    Sometimes, the last four digits of the phone number will not work as the unlock code, especially if your daughter has changed the code. Even if the phone is locked, dial *228, then press 1 when prompted by the automated system. When it tells you: "Your phone has been programmed successfully", press "Done" or "OK". Once the phone has powered off, then back on, (it will do this automatically) the lock code for the phone will be changed to the last four digits of the phone number. For example, if the phone number is (315) 123-0101, your lock code, after following the above instructions, will now be "0101". Also, you do NOT need to know the lock code that your daughter had for this to work. After the phone has powered back on automatically, you will be able to use the phone normally. *228 does not delete text messages, contacts, etc, but it WILL give you access to a phone which has been locked, without requiring you to know the code that she has set.
    Jun 24, 2009 | LG VX8300 Cellular Phone
    Us cellular lg rumor forgot lock code
    If you can’t recall your lock code, try using the last four digits
    of your wireless phone number. If this doesn’twork, call Sprint
    Customer Service at 1-800-SPRINT1 (1-800-777-4681).
    Jun 13, 2009 | LG RUMOR Cellular Phone
    Can not unlock keypad on lg envy
    dial *22899, press send, allow the phone to program completely. it will shut off on its own and when you turn it back on, the lock code will be set to the last 4 digits of your phone number!
    Jan 14, 2009 | LG enV VX9900 Cellular Phone
    Lg dare keypad is locked
    Is your keypad locked where it wants a 4 digit pin try 4 zeros or the last 4 digits of your phone i work for verizon so let me know whats going on will figure it out..
    Thanks,
    Steve
    Jan 05, 2009 | Cell Phones
    How to unlock LG VX4400
    Many people never program a password code to "Unlock" this phone, but can lock themselves out by pressing the # key for more than three seconds. I know, it happened to me when I was out of town and needed the phone to work! Anyway, press the button to the right of the large round button at the top of the keypad, you will get a prompt to enter the four digit "Unlock" code. The default from Verizon, and most likely the factory default from LG, is the last four digits of your cell number. Did this work for you too?
    Mr Dennis
    Nov 27, 2007 | LG VX4400
    Forgot Keyboard Lock Code
    Three worked for me agagined a new number to phone it was the last four of the phone number
    Oct 19, 2007 | LG enV VX9900 Cellular Phone
    LG CHOCOLATE VX8500 Cellular Phone Logo
    546 people viewed this question
    Top LG Cell Phones Experts
    George Etukudo
    George Etukudo
    Sheldon Dedek
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
