Question about Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual
Rubber on wheels is shot. Where can I get new rubber?
I have a Rockwell International 14" band saw . the rubber on both the upper and lower pulleys is no good. the Model is 28-2CO. Where can I purchase new rubber guide wheels
    President:
  • 1,996 Answers
Here are a few links to new tires for your bandsaw, available here and here and here. If you google "bandsaw tires", you'll find they are pretty widely available and may be able to come up with a better price...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
How much does a rockwell 14" band saw cost?
It has been discontinued by Delta. It would be hard to find replacement parts for this band saw. I think Rockwell 28-20C would cost $100-200.
Aug 02, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
Where can I purchase a replacement tire for a Craftsman 7 1/2 inch band saw ? It is for the lower drive wheel and is app. 10 inches in diameter. It is rubber.
I love using both rubber and urethane tires. My old 14" band saw runs for 15 years with rubber tires on it; I changed it when it started cracking with urethane tires that I got from bandsawparts.com
Jun 09, 2014 | Saws
Tire comes off of wheel
This could be a big wild guess on how the tire comes off on the wheel. But I'll try to help you this thing. I don't know if your bandsaw has adjustment bolt above the upper wheel and below the lower wheel, but in case there is , use these bolts to center the band saw. Well, this could also be blade tension adjustment. Tires should be a very tight fit and a struggle to get on.
Wait, was tired glued on? If not, reglue.
Is that an old tire? If yes, tire must be well worn out and time to invest new ones.
I recommend you to use this time urethane tires rather than rubber tires.
Rubber tires works fine but urethane tires last longer and doesn't need gluing. When you purchase a new tire, make sure that it is a couple of inches smaller than the wheel to stretch the tire. It is a good advice to slightly tilt the top of the drive wheels towards you. I've been purchasing urethane tire with www.bandsawparts.com. Got one from them and still up running. Piece of advise also,Before installing the new tires, you double-check the surfaces of the pulleys to make sure the surfaces are clean and true.
Nov 03, 2012 | Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Nov 17, 2008 | Saws
Rubber bands pop off of wheels
My Delta 14" had the same problem. My fix was to get new rubbers, took care of my issue. They do stretch, but the newer the rubbers are the more the will retain there form, the older they are, not so much.
anaanymous
Oct 10, 2008 | Ridgid 14" Band Saw with Stand
Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual Logo
446 people viewed this question
Top Delta Woodworking Saws Experts
Paul Sikkema
Paul Sikkema
Terry Weaver
Terry Weaver
Are you a Delta Woodworking Saw Expert? Answer questions, earn points and help others
