Question about GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player
What screw size is used to mount under counter radio model KCCD6316DT
3 Suggested Answers
SOURCE: What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Posted on Apr 27, 2009
  • 5685 Answers
SOURCE: Dool latch will not unlatch. Built-in model under
Hello, Let the unit cool down from the last wash. This will allow the parts to contract. If you look under the door there is a cavity below the dishwasher which usually has a faceplate. Sometimes it has screws holding the faceplate on. Remove the faceplate.
There are leveling screws on each corner of the dishwasher cabinet bottom. Right now you do not know whether the doorlatch is jammed because the base is too tight and is pushing the dishwasher into the countertop; or if the leveling screws are loose and the dishwasher is hanging FROM the countertop.
Most likely the leveling screws turned themselves looser from the vibration of the appliance operating. Just adjust the levelers properly and the latch should work normally afterwards. When you manage to get the door open, make sure you level the unit with some water in the machine bottom and some heavy dishes in the top tray. The front of the dishwasher should not be lower than the back.
I hope my solution is very helpful in fixing your product.
Posted on Mar 30, 2011
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
Will not play Movies but will play Music
  • Media player is ultra-slim and mounts under cabinet to save counter space
  • LCD TV with 7-inch screen comes with 181-channel cable-ready tuner
  • TV screen swivels for variable viewing angels
  • Digital tune AM/FM stereo radio with station presets with dual front-firing built-in speakers
  • LCD display with blue backlight
  • Instant weather band
  • Digital clock timer, timer sounds to alarm or radio
  • Auxiliary audio/video input jacks
  • FM wire antenna
  • AC powered, built-in AC line cord
  • Battery back-up against power failure, remembers time
  • Uses two AAA size batteries for back-up (not included)
  • Soft-touch membrane remote control with direct channel select
  • Under-counter mounting template
check if your player can read mpeg, avi. divx, etc..
Aug 10, 2012 | GPX KCL8806DT 7 in. Portable Television
I don't know how to take my Gatco 4515 "Tiara" Robe Hooks off the door now that I'm moving. Please help. Thank you.
I'm not 100% sure about this model, but I have a similar hook by another brand. Here's how mine is removed:
When you look at the hook, there's a small hole at the 6 o'clock position, (pointing down, right next to the wall.) This hole is actually a set screw that can be turned with a small hex-key (aka allen wrench)
thomascha103_7.jpg The size needed is pobably about 2 mm, or 1/16 in.
Turn the set screw counter-clockwise for a few turns to loosen the hook from the mounting bracket. When the set screw is backed out far enough, the hook will detach.
After he hook is removed, you'll be able to see the mounting bracket that is screwed into the wall. Remove the screws with a screwdriver, and take the mounting bracket with you. You'll need it to attach the hook to the new wall.
If there is no set screw or hole visible from any side, then your Gatco hook might be removed from the mounting bracket by twisting the entire hook counter-clockwise.
If anyone else out there has experience with this particular brand, please chime in and correct me if I'm wrong.
I hope I've been helpful. Good luck.
Jan 19, 2011 | Gatco 4515 Tiara Robe Hook Bathroom...
Th cd are getting stuck in my gpx kccd6316dt, I
Is it still under warrenty?
Either it is worn out or it has a manufacturing defect.
Mar 24, 2010 | GPX KCCD6316DT Shelf System
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player Logo
20 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
