Question about Kitchen Appliances - Others
DYNACORD ECHOCORD S-65 -Operating Instruction Manual-
How do I find this manual?
Doesn't seem to be on line better call Beckman with serial number of the unit.
Nov 13, 2013 | Beckman Du Series 60 Spectrophotometer...
Where can i find an instruction manual for mcculloch hedge trimmer tivoli 65 pnc 953900522
Use the provided links:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Aug 26, 2012 | McCulloch Garden
Dynacord Powermate 1000 Mixer MK1 manual, where can i get one?
Do you mean teh Powermate 1000 powered mixing board? Dynacord has the manuals for some of their products on their site: http://www.dynacord.de/en/products/7/5/29_powermate.html . The direct link to the manual for the PowerMate 1000 is http://www.dynacord.com/downloads/PowerMate2_Manual_Vs02.pdf . Note the English documentation starts on page 31.
I hope this helps.
Oct 01, 2011 | Electrical Supplies
Looking for an English version of the Operating Instruction, Manual Instruction of Panasonic Digital Camera Lumix DMC Ls 65
In the settings there should be an option to select your language. English is one of the options.
Jun 17, 2010 | Panasonic Photography
Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
May 07, 2009 | Garden
Drawing of Cobra 2 Sub box
Alright, I looked up that sub and I think I know what you need. First and most importantly every sub woofer enclosure is different-made for the sub woofer you will be using. Unless you have the same exact model DYNACORD is using, your box will be slightly different. In fact depending on the sub, your box may be dramatically different. There are some people, like myself, that could help design an enclosure for you but they will probably charge for their services. Either way you can go on the internet and look at some designs to give you an idea of what you need to build. The particular design DYNACORD chose to use is called a "Vented direct radiating cabinet" (it also uses a couple other electronic goodies) a little complex to understand and build. Sure you could try to copy it but it won't work right unless you have the same sub. In fact I use a computer program to assist me in this regard, so don't feel bad if you don't get it right the first time. Good luck and I'll leave you with something from Dynacord.
-Dynami
DYNACORD´s COBRA-SUB is a vented direct radiating
cabinet, equipped with the high-power Electro-Voice EVX
180B 18" transducer.
Frequency response is 38Hz - 170Hz (-10dB), so the crossover
frequency to Mid-Hi cabinets, e.g. DYNACORD´s
COBRA-TOP can be chosen strictly application-oriented
between 80Hz and 160Hz.
The cabinet is equipped with an electronic circuit called
VOICE COIL TRACKING PROTECTION. This circuit senses
the terminal voltage of the transducer and simulates the
thermal behaviour of the woofer´s voice coil. In case of
potential thermal overload the power applied to the speaker
is reduced to a safe level.
Power amps up to 1200W/8Ohms can be used in order to
have maximum dynamic range without the danger of thermal
overload in non-controlled situations. The VOICE COIL
TRACKING PROTECTION exhibits “soft” switching characteristics,
so no annoying clicks or pops are audible. The
circuitry automatically resets after the voice coil temperature
has reached a safe value.
The COBRA-SUB cabinet is made of 18mm birch plywood.
All corner joints and braces are grooved and glued. The
cabinet´s surface is coated with an extremely durable Polyurethane
which exceeds the quality of a standard lacquer
finish by an order of magnitude. A powder coated steel grille
and a lockable cover protects the COBRA-SUB against
damage during transport and bad environmental conditions.
The connector panel uses two 4-pole Speakon connectors
(IN/OUT) for a safe connection and easy daisy-chaining to
other cabinets. The pin assignment is 1+/1-. Pins 2+ and 2-
are also connected between the two Speakon connectors.
When using DYNACORD power amp racks, the whole system
can be wired with 4-pole Speakon cables without any
danger of accidental wiring mistakes. Four recessed rigging
tracks and two webbing-strap points can be used for easy
“flying” of the COBRA-SUBs. The cabinet is equipped with
four large ABS feet that allow easy stacking and a “snap-on
flying” even in angled positions.
Two handles and four heavy-duty castors on the rear side
guarantee easy and safe transport.
Mar 15, 2009 | ElectroVoice EVX-180B Car Subwoofer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
