Question about Whirlpool GZ7730XGS Stainless Steel Kitchen Hood
Need manual for Sirius Hood Fan Model SUTC-35. Need to know how to change lights
We have sirius 900 built in. Lights (both) stopped working and apper fine upon inspetion. Fan works fine. I can also hear the light switch click every time switch is depressed. Help. Thanks.
You need to trace the path of the current (voltage) Start at the light and work backwards. Check for 110Vac at the socket. If its there you have a bad bulb, if not keep going backwards towards the switch until you find 110Vac. When you find it the problem will be in between the last 2 points you checked.
Aug 13, 2014 | Sirius Hoods SIU3 90 SS Island Range Hood
Fan under the hood wont shut off
The fan on that model has an electronic control module that is interfaced with the engine control module. Without a scan tool it will be difficult to ascertain which module is indeed at fault. Most likely the fan module has gone bad. Check the temperature gauge in the cluster to insure the engine is NOT overheating....that will keep the fan on. But from what I can surmise....it runs even when it is cold. The scan tool is going to be used to pull the trouble code stored in the ECU for the engine....this is still the best way and cheapest to diagnose.
Scott, Porsche Master Tech 35 years
Jan 12, 2014 | 2011 GMC Terrain
We have a sirius model sut900w/su900m built in range hood and all the sudden nothing works on it. Never had a problem for three years. lights nor the fans will work. Is there something on it we should...
the fuse on the unit may have broke or the breaker for the unit ay have tripped, check the breaker and if thats fine check the manual to see if there is a fuse and where it is located. If it is the fuse you can get a replacement at your local hardware store.
Jun 17, 2011 | Sirius Hood Built-in Powerpack, SU900
Hello, have a sirius range hood 600-cu.ft./min of power, 4-speed fan, electronic controls, halogen lighting. its not working at all. press controls, nothing, power is going to it, checked that. what you...
Check for power in and out of the main control board...sounds like the main board has fired...if you have power going in, but none coming out then the board is bad..
heatman101
May 02, 2011 | Sirius Hoods SU3
I have a Sirius range hood SU3. It sound like the right side of the fan blades are off-balance, because it's making a scraping noise. It is starting to get annoying. I looked at it and I don't see a way to...
Yes, I am on my third motor in a SU 4/ Sirius is brutal to deal with. All of the motors are **** and they are always back ordered. here in Canada the distributer change around 2008. They are through Maroline and a crappy company to deal with unlike the othe people in Oakville. Service sucks for such an expensive and beautiful stainless hood. Good luck and the motor does come off...
Jan 05, 2011 | Sirius Hoods SU3
Hood fan is turning on and off by itself, won't stay on or off.
What devices in the room were checked. A vent hood will sometimes run on what is called a humidistat, and anytime it senses high humidity it will kick the vent fan on. Check to see if this is the issue, if so and this hasn't happened before try changing the humidistat.
May 03, 2010 | Sirius Hoods SU3
Sirius hood fan maintenence
I do just spray with degreaser first then rinse off.
Then you can wash in the machine without worry of clogging up the unit.
Feb 27, 2010 | Sirius Hoods SIU401-22 SS Island Range...
Fan control relay error code 35 1995 Voyager
Locate the Fuse Relay Box under the Hood and Locate the Fan Relay and Change it from this Box. The Diagram should be inside the Lid for the Box or in the Owners Manual. Please Rate My Response! Thanks!
Feb 04, 2009 | 1990 Dodge Caravan
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Whirlpool GZ7730XGS Stainless Steel Kitchen Hood Logo
119 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
