Question about Genius Computers & Internet
Mouse moves pointer but doesnt click
Mouse not working
  • 26 Answers
SOURCE: mouse pointer stuck.
Hi
make sure when you chang the battery if your mouse has a light(usually red light) it is on
second make sure optical eye is clean , use air duster to clean it , if your mouse is not dameged ,now it should be working .
thanks
Posted on Dec 13, 2008
Joed911
  • 4338 Answers
SOURCE: Logitech mouse - pointer moves but left clicking doesn't work
Download the latest drivers from this logitech site:
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 14, 2009
  • 40 Answers
SOURCE: Mouse Pointer Doesn't Move
return that , it isn't your pc
Posted on Jul 04, 2009
AZinkey
  • 60 Answers
SOURCE: My mouse pointer always hangs and can't click.
may be its occurred from your motherboard ps2 pin try to usb mouse
Posted on Aug 30, 2009
SOURCE: Arc mouse doesn't move pointer (scrolls & clicks ok)
Call Microsoft at 800-360-7561 and they will replace it. All you will have to give them is the PIN number located under the battery's. You will not even have to return the original Arc mouse. Must be a big problem for them
Posted on Mar 02, 2010
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
I dropped my mouse and it appears that the inside of the mouse moved and now the sensor (red light thingy) moved and thus the pointer won't move much, clicking stuff works however, How do you open the...
try cleaning the sensor reflector b4 opening the mouse(its the light thingy @ the bottom)
if it doesnt work try opening with a screwdriver,normally covered by a sticker at the bottom of the mouse
Feb 10, 2011 | Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Pointer moves when clicking even is mouse is not moving
just open ur mouse
and clean it with cotten
and u will never got thsame problem.....
Jun 26, 2009 | Logitech Gaming-Grade MX518 (9313520914)...
Mouse doesnt work
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Mar 21, 2009 | Microsoft Wireless Notebook Optical Mouse...
Thanks, Joe
Feb 14, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Computers & Internet Logo
Top Genius Computers & Internet Experts
micky dee
Mirca Sekosan
Mirca Sekosan
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
