Question about Explorer Appliances Dora The Explorer Cell Phone
Wpm usb driver
Computer is not directed to driver software for doll
2 Suggested Answers
SOURCE: Cant get pc to recognize dora doll...Need a usb
need drivers to recognize dora play phone
Posted on Oct 07, 2009
My PIXMA2520 only prints document when scanned,and is not able to scan TO my computer Need to scan and have it appear on my computer.How can I do this?or is this printer-scanner not able to Than you
Scanning to the computer is done through the printer menu of the software you loaded to the computer when you installed the printer in the computer. The menu item you want is called "MP Navigator" and it is in printer "Canon Utilities" menu
Feb 24, 2017 | Canon PIXMA Office Equipment & Supplies
HP 2520hc scanner drivers
Which driver set did you install? Did you install the HP basic drivers, the full software or the Windows XP built-in driver? The Windows OS driver usually only is the printer driver.
If you connected the USB cable before installing the HP software, you will get the OS drivers. Disconnect the USB cable and then uninstall the printer driver. (Start > Control Panel > Printers and Devices. Then right click on the printer and select Remove Device.)
Install the HP software. If you want to launch a scan from the all-in-one's front panel button, install the full software.
Next open the scan software on your computer. (This is the HP Solutions Center for most models if you use the full software.) Attempt to launch a scan from the software. Adjust the resolution and other settings as needed. Then use those settings to adjust the destinations for the front panel buttons in the software. (Settings > Scan Settings > Button Settings)
If this doesn't work, try a different USB cable, a different USB port on your computer and a direct connection (if you are using a USB hub). Scanners require bi-directional communication with the computer and may fail when the printer works due to a minor cable issue. If you have the printer connected to a router or similar device to turn it into a network printer, again the scanner will not work. Again the direct connection to the computer is needed.
If you are still having trouble, can you use the all-in-one's copy function? If not, do you have any error messages? If the scanner mechanism isn't moving, the unit probably needs service. (This model doesn't have a scanner lock to protect the mechanism in transit.)
I hope this helps.
Oct 15, 2012 | Office Equipment & Supplies
Either software or device issues? The software doesnt recognize the device!
Here's a lil tip 4 u...not all softwares work properly in a computer even if its installed/downloaded properly with the instructor's manual
try returning it back with your insurance guiding it then get a new one and try it again...good luck
Dec 28, 2011 | Vtech V.reader Reading System
I am slow in typing,what owuld i do to increase my spped in typing?
Download the typing master. I used to be a slow typer around 15-18 wpm. I tried with the software and made improvements day by day. Now i type to around 40-50 wpm. That's almost 3X compared to what i used to type earlier. I'm sure you are likely to make improvement over this. Trust me.
Visit: (Scroll down to download)
http://www.typefastertypingtutor.com/
Regards
George
Jan 14, 2011 | Computers & Internet
I can no get my printer to scan to my computer
Do you have the full software (MP Navigator) installed? Get that software here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp510#DriversAndSoftware and select your OS. Since the printer is a USB printer, is it directly connected and did you install the software before connecting the USB cable? If you didn't install the software before you connected the USB cable, uninstall the generic driver from the OS and remove the USB cable. Then install the software.
If the full software was installed before connecting the printer, try a new cable and a direct connection (instead of a print server or USB hub). Scanners require bi-directional communication with the computer and can fail when the printer works. Make sure the monitoring program is running before attempting to scan from the all-in-one.
Next try to scan from the computer first. There are buttons in the MP Navigator software that set the destination and default settings of the buttons on the all-in-one. After you scan at least one item, you will have a better idea of the settings that you need to use. See the MP Navigator help files for the details.
If you install the basic Canon driver, you will be able to scan but not from the unit directly. Windows XP and newer all come with Paint that can acquire scans (File > Import from Camera or Scanner > New Scan). Windows Vista and Windows 7 have Windows Fax and Scan that can also scan files (New Scan). Photo Gallery in Windows Live (comes with Vista) also handles scanning.
The generic OS driver usually only runs the printer.
I hope this helps.
Dec 10, 2010 | Canon PIXMA MP510 All-In-One InkJet...
I cannot get my photosmart c5580 to scan I select scan, start can, scan to comuter and get an error says for me to start scanning from computer
What OS do you have? Do you have the full-featured software installed? If you only have the driver that was built into the OS, that is a generic driver and will not read the buttons on the all-in-one for scanning.
If you plugged in the USB cable before installing the full software, you get the generic driver. Uninstall that driver, unplug the USB cable, and install the full software. Check for updates for your software.
If you have a USB hub or print server, try a direct connection. Often these interfere with the bi-directional communication that allows the computer to see the buttons being pressed.
If the full software is installed, check if the image monitor program is loaded and running. That listens for the activity of the buttons and they will not work if the service is stopped.
Software and drivers:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3575276&
If you can't launch the scan from the computer, then try a new USB cable and a different USB port. As above try a direct connection if you have a USB hub or print server between the computer and the printer.
I hope this helps.
May 16, 2010 | HP Office Equipment & Supplies
Mavis Beacon Typing Tutor Platinum 20 shows minus wpm in progress summary even though I average 45-50 wpm,
If it's pirated thats your problem. the patch may have changed the wrong bytes in the exe file
If it's not......
try a re-install of the software if that doesn't work i'd send their product support a message at this link
http://www.broderbund.com/store/broder/Content/pbPage.ProductQuestion
Nov 11, 2009 | Encore Mavis Beacon Teaches Typing...
Computer won't recognize new Lexmark X9575 printer
Are you conecting via USB? If so, did you wait to connect the USB cable until the installation advised you to? If not, uninstall the software and driver, unplug the USB cable, reinstall the software and driver, and when prompted, plug in the USB cable.
May 18, 2009 | Lexmark X9575 InkJet Printer
White screen.
If you are using a usb hub, connect the lifecam directly to one of the usb ports on your computer.
Apr 19, 2017 | Microsoft LifeCam VX-6000 (68C-00001)...
Explorer Appliances Dora The Explorer Cell Phone Logo
35 people viewed this question
Top Explorer Appliances Toys Experts
ray gallant
Are you an Explorer Appliances Toy Expert? Answer questions, earn points and help others
