Question about Craftsman 25cc 210mph / 450 cfm Gas Blower
Wont start and no spark
Got a new spark plug and still wont start
Theres no spark and bike wont start
you will have to check lead to spark plug then lead to coil
if your not getting spark at plug it could be a number of things ingintion
or just a loose wire best of luck hope you solve it
Mar 15, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Weak spark
pull flywheel and replace sheer key on flywheel to get spark on time
Feb 23, 2014 | Garden
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
Jan 25, 2014 | 2001 Dodge Stratus
Spark plug blew out now car wont start
sounds like the autoshutoff relay may be bad..it controls the ingition and the fuel pump too..if the pump works check for spark by inserting a screwdriver into a pulled off spark plug wire and look for a decent spark between the screwdriver shaft and any ground like the block..if no spark the relay may not be powering up the ignition system..
Dec 15, 2013 | Acura RSX Cars & Trucks
Gp 800 will crank but wont start
Hi, most likely the trigger coils near the flywheel, it will still have spark but the timing may be off. Try new plugs first as they may have spark outside the cylinders but not when under compression. Regards Phil
Jul 01, 2012 | Yamaha Boating
My dr 1990 model wont fire
try pulling the plug, stick a screwdriver in the end of the spark plug wire and hold it to the metal of the bike try starting it if it has fire you wil get a spark. if no spark try checking the points they may have burned out
... good luck
Jun 02, 2012 | Suzuki DR 750 S Motorcycles
Wont fire
You have to check of there is sparks at the spark plug and also if the fuel is being injected to the combustion chamber.
Crank start the engine for a short while and thn remove one spark plug, if fuel is injected you will see tht the plug is wet.
To check for sparks to the plug, wipe tht plug dry if its wet due to gas, thn earth the spark plug body to the engine and crank start, if theres sparks you will see.
If you both of these thn it the engine must fire.
I guess one is missing.
Hope this helps!
Dec 19, 2009 | 2005 Triumph Sprint ST
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Craftsman 25cc 210mph / 450 cfm Gas Blower Logo
43 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
