SOURCE: Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
SOURCE: upper thread breaking on singer machine
Check that your bobbin thread is not wound too tightly or too loose. Also adjust your tension down a click at a time until it stops breaking, testing on scrap fabric. Singer provided manuals online. Look it up here: http://www.singerco.com/accessories/manuals.html
SOURCE: What is the thread path on the Singer sewing machine Model 7110
web site www.sewusa was gread threading diagrams
SOURCE: Thread bunching under work
Clean away all the thread.
If you look through the Singers at Relics.com you may find your machine and order a manual so you can be sure the bobbin has been threaded and is inserted correctly into the machine.
It is possible the timing has to be adjusted - you can find this at sewusa.com
SOURCE: How to thread the Singer CAT#RFJ8-8 machine?
You can find Singer threading diagrams at http://www.singerco.com/resources/threading.html.
