I type in the gateway in to the internet browser but can not get into the setting to config
Your Connectivity may be on Wifi or Lan, ping the gateway and verify gateway IP is up and running if not then try to manually assign the IP to the system and try ping and if there is any proxy Please also remove the proxy from the internet settting and if still problem.Then reset the modem and then also set the IP of your system 192.168.1.2 and access the by default IP 192.168.1.1 and configure the acces point
SOURCE: D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
SOURCE: How to reset UtStarCom W3002G4 modem
at the back of the modem, you will find a small reset screw, reset with a pen or a pencil and restart the computer
SOURCE: DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
Reset the DSL Modem and make sure the modem is setup for your DSL account information. You might have to call up your ISP for that information to be added. If that was done prior then the Router has to have the same information user name @ your ISP.net or .com and password. for PPOE. Make sure the router has it MTU set to 1492 for DSL.
1. unplug the modem
2. unplug the router
3. between both of them wait 30 seconds
4. all PCs should not be on
5. plug in back the modem
6. plug in back the router
7. Turn one one PC
8. login to the router and make sure it connects to the internet
Since your using Gig Router make sure that the WAN is to 10 if you have 6Mbps plan 15 to 30mbp plan go to 100 for WAN.
If you're still having issues, then you need 3rd level service tech from your ISP to check the DSL back at the office side to see how that's connecting to your modem. If that checks out okay, then have line tech come out and check the DSL going into the house. If that checks out good then it could be the a problem with the new router you have there you have updated the firmware for it yet?
If you have then the modem could be the problem. These are the steps you need to take to trouble shoot the problem. Check all connections make sure they're plugged in correctly. Make sure all DSL filters are working correctly one bad filter can throw the DSL off. Check each phone connected to a filter to see if its clear.
SOURCE: Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
open internet explorer
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
[email protected]
