Question about Sony PlayStation 2 (PS2) Console
Game is undefeatable
This is not a question about the PS2, per se, it is about a game, Beyond Good & Evil (primarily made by Ubisoft), I need to know how to defeat the boss on the "moon" level at the "end" of the game. (the weird-looking creature w/ 3 eyes in a triangular formation. Thanks, also, if there are any, I would like some "cheats" for the same game (primarly invincibility/invulernablity/"god mode")
  • Chris P.
    Chris P. May 11, 2009
    Sorry, but the site is blocked. :(
    Problem Solver:
  • 15 Answers
Moon - Selene
First, shoot the whale that's flying around tossing ice at you, until the ice
is COMPLETELY gone. Take a photo! This gets you the final photo... and the
Mdisk from the science center. Then just point to the moon, and drive
straight... once there, aim at the transmitter's bottom area, and fly into
it.
Inside of the transmitter, kick open the materia crates, and buy EVERYTHING
in the vendor, you'll need it all. On the wall by the vending machine, is the
map to analyze. Save the game. Push the button on the floor to get the crate
to come over. Hop up the machinery until you can jump onto the crate, then
have Double-H push the button. Jump off when it stops moving, and you'll land
on top of the Beluga. Jump up, and toss a disk to the far button to bring the
OTHER crate up, then toss ANOTHER disk at it, and quickly jump on board.
You'll end up on the other side. Use the gear in the corner, to lower the
bridge for Double-H. This will serve a purpose later, I just like to get it
out of the way now :) You don't have 3 things to hold down the buttons, so
run the OTHER way, into the elevator shaft. You stand on one button, Double-H
on the other.
Welcome to the DomZ base... reminds me of Aliens. Run over to the mirror
that's beaming the light towards the elevator. Next to it, is a mirror on a
pedestal. Grab it. Across from the door, is a place to put the mirror, insert
it. Run over to the mirror that's currently shining the light. Tilt it over
to the mirror you just placed. Then, tilt the mirror you just placed, to the
LEFT, until you light the crystal over there. This lets you get a second
mirror. After grabbing it, head back to the mirror you turned, and turn it to
the doors to open the next path. Run through, but don't bother with the
mirrors yet. Keep running, to the Cloister where Pey'j is imprisoned. Run to
the door behind him, and save. Only Jade can fit through here...
In this next area, to the right, are two alpha sections guarding a grav shaft
leading down. In the open, like this, they're a CINCH to kill with the super
attack! On the left of where you entered, is their ship, with some materia
crates, if you want them. After you're done collecting whatever crates you
want, and killing the two, head down the grav shaft. Circle around the Great
Crypt until you find the door, then run inside. Hope you don't get vertigo!
Your objective is to get to the green shaft. Look around you, and map out
where to go. It's not too tough! All paths lead there, in the end... once
there, take the last photo you need... now head all the way back to Pey'j.
(You want the DARK BLUE shaft to get back up)
Head back to the beam of light. You need to reflect that all the way to
Pey'j! Put the mirror you picked up, into the pedestal under the beam. Now,
if you want more money, reflect it over to the right to get the materia
crystals. If not, reflect it to the left, to the mirror in the other room.
Here, you have to reflect the beam from the left mirror, to the right mirror,
to the middle mirror, and then across all the crystals. It's done with the
Disk launcher now! Shoot two disks at the right-side of the left mirror, and
it should spin and hit the right. Hit THAT one with two disks, and it should
hit the middle. THe middle one only need to be hit with one disk. Run back to
the Cloister. Here, turn the mirrors so that all the crystals on the OUTSIDE
ONLY are lit up. Next, turn JUST the mirror that the beam of light is hitting
from the outside. This should light up all the middle ones, without having to
turn anything! Lastly, tilt the same mirror one more time, to light all the
inner crystals, and expose Pey'j. Double-H can break Pey'j free.... but
sadly, it's too late...
(For the detail minded... shouldn't Pey'j be missing his suit and boots? Yet,
he has them... heh, call me anal retentive for noticing the minutia like
that)
Head out of the Cloister, back to the DomZ base. You'll get a message, from
Mei... and look who's back! Head back to the ship, now. The area that you
opened up before, now you can open the door there, since you have 3 people!
Head inside, and you're attacked by a turret. To get past, you need to duck
to the side while it's firing, and run when it stops. Once beyond the turret,
enter the trolley to head to the radio transmitter room. Take a photograph of
the serial code here, then input the code you get, and enjoy!
After the Long cutscene, head back to the trolley, then to the ship. As you
exit the base, you're attacked by the Alpha Section General. His ship can
take a huge beating, and has several attack modes. Listed are each mode and
how to beat him. You can only use the neutralizer cannong for this, but that
just makes it easier... this is, FYI, my favorite fight :)
First mode - no sweat! Just fire at the glowing targets.
Second mode - aVoid the center engine area, it fires at you. Between shots,
fire like mad at it!
Third Mode - Avoid the white streams of energy and fire at the glowing
targets. You don't have to aim STRAIGHT at them.
Fourth mode - Stay away from the center area, but watch out for the mines he
tosses back at you. Between shots, fire at the center.
Fifth mode - Stay towards the edge of the screen, and take out the glowing
targets.
Sixth mode - Just like the fourth, only this time you don't aim at the
center, you aim at the glowing targets.
Seventh mode - Stay clear of the white lines and the electricity by staying
at the far edge of the screen. Fire at the glowing bits.
Eighth mode - Last mode. Don't worry about taking damage here, one shot will
kill him. Aim at the center.
Once he's down, blast the two mines in the middle, by either using the black
floating barrels, or luring torpedos in. Inside, save and move in. 3 Alpha
Sections will attack, but your friends should be able to distract them long
enough for you to get off a few super moves to destroy them. Head up the grav
shaft, to see the last words of the General... head back to the hovercraft,
then to the ship. When you head back to the base, you're attacked by a huge
force! Use the neutralizing cannon to shoot down as many as you can, until
reinforcements arrive. The battle looks AWESOME, doesn't it? :) Then head
into the base. BEFORE YOU GO DOWN THE ELEVATOR, REMOVE EVERYONE'S PA1'S AND
GIVE THEM TO JADE! Trust me, it helps a ton. Once you're ready, head into the
Great Crypt. Be sure you have tons of K-Bups prepared. This is the hardest
fight in the game...
+++ FINAL BOSS +++
For the first part of the battle, just kill the DomZ Sarcophagi that attack
you. Then, as the boss moves away from the statue, back up and use a couple
super-attacks to hit him with the purple orbs. He should retreat back to the
statue. Now he'll guard himself with huge materia spikes, and attack with
clones of Pey'J! That bastard! Double-H's super attack can pop the pey'j
clones into the air, so you can knock them into the materia spikes. Get rid
of the spikes in the middle, then send a pey'j clone flying into his body to
hurt him. Beware, every time you kill a pey'j clone, a Sarcophagi attacks...
Once you hit the body with a Pey'j clone, and kill all the sarcophagi,
Double-H is taken...
This part is tough, but the boss ALWAYS attacks in a set pattern. Each time
you miss or mess up the pattern, he'll hit you and take off 2 whole hearts,
which is why I said to stock up on the K-Bups! If you know the pattern,
you'll know where he appears. The pattern (Relative to your position) is :
Left, up, right, left, up, right, above, down, right, up
(Above means you have to charge your Dai-Jo staff to hit him)
So, if I say left, he'll appear to your left, and you have to hit him there.
Once he's been hit several times, he'll send in a bunch of clones of Double-H
to attack... PLUS he shoots green lasers at you, and killing a clone releases
a sarcophagi! Kill all the clones (Super attacks work best), then kill the
sarcophagi. Ignore the lasers, as best you can.
Now, it gets trickier.... he reverses your controls! Right is left, up is
down... but he's almost gone, and things slow down, giving you more reaction
time. He'll send in a few Sarcophagi, get used to the controls... now he'll
attack again, appearing in a different pattern this time. The pattern which
he appears in, is...
Left, right, left, Right, above you, right, up, above you, DOWN.
Remember, you controls are reversed, so if he appears to the left, you have
to press RIGHT to hit him. Once you lay the final blow on him, you win the
game! Congratulations!
And ther are no god mode cheats.. sorry
Hope it helps
Posted on May 12, 2009
    Problem Solver:
  • 12 Answers
I cant find any cheats but here are some hints
http://www.cheatcc.com/psx2/bgae.html
hope this helps
Posted on May 08, 2009
My Resident evil 2 doesnt work anymore. I have the playstation 1 version and it stopped working in my ps2. When i put it in, it just makes a skipping sound and after about a minute it returns to the...
this isn't my area of expertise but if you really wish to play resident evil, go on doperoms.com and go to emulators, choose a psx emulator and then download it then you can download any ps1 roms like resident evil and play them for free on your computer. it doesn't take a powerful computer, these games will run on an iphone 3g, leave a good rating if this helps
Mar 01, 2011 | Video Game Consoles & Games
Cheat for resident evil 4 in ps2
Visit this link to get all the cheat codes for resident evil.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 07, 2010 | Sony PlayStation 2 (PS2) Console
Looking for a ubisoft game manual and not sure if this is a location that will help..not much of a gamer, but need manual for ps2 Heroes of the Pacific game. I looked on the "ubisoft" site but didn't see...
FLIGHT CONTROLS blacklinespacer.gif Steering or Roll: Left analog stick Left/Right Change Pitch of Plane: Left analog stick Up/Down Roll Left/Right/Move Vertical Rudder Left/Right: Right analog stick Left/Right Throttle: Right analog stick Up/Down Engage Warspeed: R3 (click right stick)
blacklinespacer.gif COMBAT CONTROLS blacklinespacer.gif Give Wingmen Order: Attack: Directional Up Give Wingmen Order: Defend: Directional Down Give Wingmen Order: Break: Directional Left Give Wingmen Order:Form Upk: Directional Right Next Target: x.gif Closest Air Target: Hold x.gif Rear View: triangle.gif Cycle Secondary Weapons: square_white.gif Next Objective: circle.gif Closest Objective: Hold circle.gif Target Camera: l2.gif Fire Secondary Weapon: l1.gif Zoom In Gunsights: r2.gif Pause Menu: Start Change View: Select
From http://www.gamesegment.com/PS2/instructions.cfm/id/6386730
Nov 17, 2009 | Video Game Consoles & Games
Resident Evil 4 game for ps2 won't start at begining
hahahahahha upgrade to xbox 360 you ******* *********
Sep 20, 2009 | Capcom Resident Evil 4
I cant find the cheats for evil dead-fistfull broomstick its on ps2
It seems there are no cheats for this game only a few unlockables
SEE
Sep 13, 2009 | Sony PlayStation 2 (PS2) Console
Resident evil code vernica for ps2
I say the best thing for you to do is go to google and type in walkthrough for resident evil code veronica x for whatever system you have the game to help you out on that. Also you can have it if you happen to get stuck on another part you will have something to help you out. Let me know if this works Good Luck!
Jan 20, 2009 | Capcom Resident Evil: Code Veronica X
PS2 strange problems.....
okay, maybe your game has the problem, maybe you should check first the cd for some scratches or some cracks before you play it
Jun 17, 2008 | Sony PlayStation 2 Slimline Console
How do I get an account for online play?
check sony website, theres might be more information on game that need account.
Jun 10, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
184 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
