Question about HP PSC 1610 All-In-One InkJet Printer
Paper jams with photo paper only hp1610 all in one. will print photo on regular paper any size.machine also makes a "grinding rotating" noise
    Brigadier General:
  • HP Master
  • 3,614 Answers
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Posted on May 28, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
The copier experienced repeated paper jams
Pl. mention make/ model and where it jammed. if possible the photo of the jammed paper inside the machine. Also mention the total pages printed in A4 and A3 size.
Thanks.
Dec 13, 2014 | Office Equipment & Supplies
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
Hello, I have a HP Color Laserjet 5550DN that works great. Except when I try to print out some photo's on a regular piece of paper. It says "not enough memory". The photo's are about 4MB...
It has 4 memory slots. If you can add what you need to get 512 meg, that should fix your problem.
You say that "some photo's on a regular piece of paper." , get the error, but if you use photo paper it prints ok. Doesn't make sense. Add the memory.
Jun 27, 2011 | Office Equipment & Supplies
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
I can't get my brother printer to print photos Keeps saying paper jam even though no paper jam
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Sep 23, 2010 | Brother MFC-685cw InkJet Printer
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
HP psc 1315 all in one-printing cards
Make sure you check the settings in the print driver. Sounds like your paper size settings do not match the size of the paper that you are printing onto and you are actually getting a false jam because the machine is seeing a different size paper then you ahve in it.
Dec 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
124 people viewed this question
Seeker5211
Seeker5211
