Question about Kyocera FS 9530DN - Printer - B/W - duplex - laser - A3, Ledger - 1800 dpi x 600 dpi - up to 51 ppm - capacity: 1200 sheets - parallel, Hi-Speed USB, 10/100Base-TX
Como corrigir o erro 7900 da kiocera 9530 - Kyocera FS 9530DN - Printer - B/W - duplex - laser - A3, Ledger - 1800 dpi x 600 dpi - up to 51 ppm - capacity: 1200 sheets - parallel, Hi-Speed USB, 10/100Base-TX
COMO RESOLVER ,POIS O MONITOR NAO LIGA?
Oi Anonymous, Verifique a ficha n?o est? solto no monitor eo computador .... e se nada solto em seguida, O link abaixo ? um v?deo do YouTube mostrando como corrigir tela preta, tamb?m h? v?deos para o lado direito do link que voc? pode considerar a pena olhar, bem como, infelizmente, o link est? em Ingl?s ..... espero que isso ajude ... .CHEERS ..
How to FIX Windows 10 8 7 Black Screen of ***** With Cursor After Login...
Apr 27, 2016 | Computers & Internet
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Como resolver o erro da cp5525 laserjet color
please would write English so can i understand you
i can help you do not worry , just go to Google translator covert your message to English , then i will reply you with propor answer
Hope help you
Sep 23, 2013 | HP Color LaserJet Enterprise CP5525xh...
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
Sc 335 da Ricoh 1075, como solucionar?
Olá!
Esse erro está relacionado com o Motor Poligonal do Laser.
Antes de mais deves actualizar o firmware da maquina. Existe uma referência que corrige esse sintoma.
Se depois da actualização o problema persistir poderá ser 1 destes problemas (por ordem de solução):
1-Mau contacto nos cabos do Motor Poligonal.
2-Motor Poligonal avariado.
3-Placa IPU avariada.
Espero ter ajudado.
See you!!!
Apr 01, 2011 | Ricoh Office Equipment & Supplies
Como posso corrigir erro impos impr 4f brother dcp 130c.
4F message indicates that the printhead is RIP, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Feb 20, 2011 | Brother DCP 130C All-In-One InkJet Printer
Kyocera FS 9530DN - Printer - B/W - duplex - laser - A3, Ledger - 1800 dpi x 600 dpi - up to 51 ppm - capacity: 1200 sheets - parallel, Hi-Speed USB, 10/100Base-TX Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
