Question about Samsung NP700Z3A-S06US - Series 7 700Z3AH - Core i5 2450M / 2.5 GHz -
Manual cd eject
I need to eject a recovery cd using the keyboard
Is there a button on the key board to eject a cd from slot load cd player
It depends on the type of keyboard you are using. If you are using a keyboard which have multimedia buttons, you can eject the CD from player, other wise you can not do this.
Oct 20, 2011 | Microsoft Windows 7 Professional Upgrade...
I have 2 problems. My Acer Aspire 560z keyboard types garbage for some reason, so I am using an external KB. Then, I want to restore the laptop to factory settings, but the cd's are lost. I don't...
Keyboard - Do you have the NumLock on?
From the ACER support site:
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 12, 2011 | Acer Aspire 5610 Notebook
I am unable to open my cd drives with the keyboard
On your keyboard:
Press the Windows key.
Use the keyboard arrows to navigate to the My Computer icon, and to highlight it.
Press the Enter key.
Press the Tab key, repeatedly, to highlight the icon for the CD-drive.
Look on the bottom-right of your keyboard:
SPACEBAR, ALT, WINDOWS, other, CTRL
Press that "other" key.
Use the keyboard arrows to highlight EJECT.
Press Enter to "open" the CD-drive, and to "eject" the CD.
Feb 12, 2011 | Packard Bell 5121 (120159) Keyboard
How to restore my acer aspire 6920 to it's original setting?
http://acer.custhelp.com/app/answers/detail/a_id/161
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our Acer Recovery Media Order Form.
Dec 01, 2010 | Computers & Internet
My netbook will load up so far and then it will go blank and turn off even though it is fully charged
You will need to re-instal the OS again.So here is how:
Note: If you do not have a set of Acer Recovery Media they may be purchased online at Acer order form..
Nov 13, 2010 | Acer Aspire One Netbook
It displays the following message windows faild to restart. a recent hardweare or softweare m.ight be cause . to fix the problem:
Note: If you do not have a set of Acer Recovery Media they may be purchased at our online Acer order form..
Oct 31, 2010 | Acer Aspire 5610-4648 Notebook
Screen is not working
Oct 31, 2010 | Acer Aspire One PC Notebook
Have a acer extensa 5630Z. selling it so need to restore to factory settings. please help. thankyou
  8. Note: If you do not have a set of Acer Recovery Media they may be purchased at online Acer order form..
Oct 28, 2010 | Computers & Internet
Disk won't eject on my iMac
Ok, I assume you have hit the eject button on the keyboard. Try dragging the CD icon on the desktop to the trash can. If that doesn't work, Shut down the computer and start up while holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Another option is to open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder. Another option is to Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Lastly if your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button. One of these should work.
Sep 03, 2009 | Apple Mac mini G4 Desktop
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Samsung NP700Z3A-S06US - Series 7 700Z3AH - Core i5 2450M / 2.5 GHz - Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
