Question about Staples SPL-P500 Printing Calculator
Change ink cartridge on SPL-P500 - Staples SPL-P500 Printing Calculator
Why doesn't the equal button work when I do additions and subtractions?
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
Sep 13, 2016 | Staples SPL-P500 Printing Calculator
How to change ink rollers in calculator
How do you change ink in the Staples SPL-P500?
Jan 17, 2013 | Staples SPLP500 Scientific Calculator
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
LG P500 Cell Phone Zawgyi unicode font download
i have zawgyi one font, but i can't change to zawgyi one font on my LG-P500 , please, help me ...how to change .....
Jun 25, 2012 | LG P500 Cell Phone
Where can I get instruction on a spl-p500 calculator
Go to a web search page and type in spl-p500 calculator instruction manual.
May 02, 2011 | Office Equipment & Supplies
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Spl-c error - uw_color < 5
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 08, 2011 | Samsung CLP 300 Laser Printer
Staples SPL-P500 Printing Calculator Logo
199 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
