Question about Vehicle Parts & Accessories
Wire diagram bypass passlock 1999 6.0 silverado
SOURCE: I am looking for a wiring diagram for a 1999
Your BEST and cheapest bet is to go to a local parts house e.g. Autozone, Advanced Auto, O;Reilly's, or Pepeboys. Ask for the HAYBES SERVICE MANUAL for your truck. It costs about $20.00 and should have everything that the average guy needs to make minor repairs to their stuff. Good Luck, thanks for allowing FixYa.com to help get you going! Rate as required, Again, Thank You.
Posted on Jun 27, 2010
  • 49 Answers
SOURCE: what wire do I cut
You Cannot cut any wires to bypass on this system. The passlock security needs to see a valid key in order to have the PCM enable the fuel and Ignition. This system is complex and cannot be bypassed with the cutting of a wire.
Posted on Dec 20, 2010
  • 743 Answers
SOURCE: I need wiring diagrams for
You can get free diagrams at autozone.com in the repair section. You will have to register but that is also free.
Posted on Sep 23, 2011
tayjoejoe
  • 2194 Answers
SOURCE: How do you wire in a passlock bypass system on a
Check out this link. The passlock system is complex and tied in really well. You'll find skirt of good info on this link.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on Apr 11, 2012
SOURCE: how do u bypass the passlock on a 1999 alero
u need to find a gm self learning passlock.
Posted on Jul 06, 2012
How to bypass passlock on 1999 chevy blazer
The most common repair is to replace the ignition lock cylinder due to broken wires inside the steering column. Most common problems related to the Passlock family involve the Passlock sensor. The sensor is part of the ignition lock cylinder on Passlock I and Passlock II systems. ( Where the key goes ), Good-Day!
Aug 27, 2014 | 1999 Chevrolet Blazer
1999 oldsmobile bravado wont start .need to bypass the passlock theft deterrent system
i think i know what the issue is. I had the same problem. There is a moduel that will bypass and fix it. You can do it yourself. They guarantee the part so i it doesnt work for some work for some reason u can send it back.. Hope this helps ya Do It Yourself GM Security bypass
Aug 18, 2013 | Megatronix - PASSLOCK-SL2 - GM Passlock...
I have a 1999 chevy silverado and the security light comes on and stays on. After awhile, the light begins to flassh and the truck will not start till I reset the security system. how do I fix this?
you need to turn ignition on and leave key in on position for ten minutes then turn key off then back on again for another ten minutes then one more time for a total of three times or 30 minutes and the system should relearn the key. System is called passlock. I can email you the procedure form alldata if you want.
Mar 30, 2012 | 1999 Chevrolet Silverado 1500
What is the passcode for the anti theft system
his vehicle has a the PASSLOCK II key
based engine disabling system.
You can attempt to put the key in the ignition,
turn it on to just before cranking and then leaving
it that way for 10 mins. After that,
some PASSLOCK systems will re learn the code
and allow for starting. But if not, the system
will either need to be seen by GM or, a bypass module
is required to circumvent.
If left unchecked, it will continue to lock down
the fuel injector rail, and you will need to tow
it in to GM for evaluation, and resetting anyway.
Bothersome, but can be fixed.
I suggest the PLJX bypass kit to get around
this issue. www.PASSLOCK2.com
This Passlock Bypass Module is designed to momentarilly
allow the engine to remote start by sending a proper
coded pulse to open the fuel rail passlock injector
cut off circuit.
The output from an alarm/remote starter
would then shut down the pulse, once it has detected
the engine has engaged, and preserve the integrity
of the passlock system.
That is it's designed purpose.
However, in your case, this input wire on the PLJX module,
instead of going to a momentary ground pulse from
an alarm/remote starter,
would go to a constant chassis ground, through
the bypass module, grounding out the PASSLOCK.
The PASSLOCK would then always be bypassed as long
as that wire is chassis grounded.
I can not speak about a damaged passlock system,
like if a thief has destroyed it, because I do not
get into this part of GM'S security application.
But as a happy coincidence to installing
after market remote starters, this does work on bypassing
passlock in most all GM vehicles we've run into,
including your year GM vehicle as well.
Also, this is a self learning, resistor sensing
and adjusting module. Once the VATS wires have been tapped,
you would press the program button to learn,
and it does. The car should then allow start
with any hardware store key.
It would on yours as well.
You might want a car alarm installer to do this
for you, the fair rate being around 50. to 75.
for labor.
Jan 26, 2011 | 1999 Chevrolet Malibu
1996 buick skylark..alarm theft keeps flashin..try to start..it turns but wont stay running..
Need a bit more information, Is the security light on, have you checked for spark and fuel pressure, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
have a great day. Sorry the pictures won't come up, but check out the site
GM Passlock I & II Information
Please study the following information carefully WHEN INSTALLING REMOTE START systems on a 1996 or later GM car or truck.
Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the GM V.A.T.S page for more information.
To remotely start a car with this feature, you must bypass the PASSLOCK system. There are two methods of doing so.. The first, is to permanently bypass this system. This is the easiest method for accomplishing your task. The second way, is to temporarily bypass the PASSLOCK, by introducing relays into the system, which retain all of the features of the system, while allowing your remotes start module to bypass it automatically during a remote start cycle.
Vehicles effected
(1996 and newer): N & J body cars, such as
Pontiac Sunfire and GrandAm Passlock-1
Chevrolet Cavalier Passlock-1
Buick Skylark Passlock-1
Oldsmobile Achieva Passlock-1
1997 or newer
Chevrolet Malibu Passlock-II
Oldsmobile Cutlass Passlock-II
1998 or newer
All trucks , SUVs and Vans Passlock-II
It is important to pay special attention to the fact that there are many different ways of achieving the same goal. There are actually 2 different Passlock-II systems. On the next page, there are tests to establish which type of passlock-II your car has.
Relays shown are standard automotive 5 pin spdt relays, available from IEI.
A multi meter is required to measure the resistance values. Accuracy is important within 5%.
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (Radio Shack2.gif, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
pslc1.gif Passlock-I bypass procedure....
1: Remove the top and bottom shrouds from the steering column.
2: Find the 3 wire ribbon cable2.gif, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
3: Locate the Black 6 position connector on the LEFT side of the steering column, right above the ignition switch position. There is a BLACK (Thin) wire in this connector, called "Bulb Test", which shows Ground with ignition in the Off position, OPEN in the "Run" position, and GROUND in the "Crank" position.
4: Turn the ignition switch to the "Run" position. Do not crank the car.
5: Cut the Thin Yellow wire and strip both ends.
6: Without cutting the Black wire, expose some of the copper.
7: Using the ohmmeter, measure from the Yellow wire (the end coming from the ignition switch), to the exposed Black wire and record the value. Measure more than once to assure you have the right value.
8: Acquire the same size resistor and 3 relays, and perform the connections shown in the diagram below.
pslk2.gif PASSLOCK-II bypass procedure
There are 2 types of Passlock-II systems. To determine which system you have, follow these instructions;
1: Locate two wires, which are THIN and are in the main ignition harness.. Orange/Black (or Black) and Yellow.
2: Cut the Yellow wire, and strip back some of the insulation from the Orange/Black (Or Black) wires.
3: Turn the ignition to the "Run" position ( don't crank the starter). Measure and record the value measured from the KEY SIDE of the Yellow wire, to the Black/Orange wire.
4: Turn the key to the "Crank" position and release. Now read the value again.
pslk3.gif5: If the value changed, follow "Method#1". If the value stayed the same, follow "Method#2".
These diagrams are from our friends at ALARMTEK AUTO ALARM
Need additional assistance?
Oct 22, 2009 | 1996 Buick Skylark
My son has a 1999 grand am, just like the oneshown above. the car wont start because the security sys. shuts off the fuel sys. down. the manifold still has good pressure cause we just had thefuel pump...
Need a bit more information, Is the security light on, have you checked for spark and fuel pressure2.gif, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present2.gif during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the GM V.A.T.S page for more information.
Vehicles effected
Chevrolet2.gif Cavalier Passlock-1
1997 or newer
Chevrolet Malibu2.gif Passlock-II
1998 or newer
Once the value of the resistor is measured, a resistor of the samevalue +/-5% must be purchased (Radio Shack2.gif, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
Oct 05, 2009 | 1999 Pontiac Grand Am GT
Why the 1500 silverado does run good but stalls and then after turning the switch of and recrak it does starts ,runs good for a few minutes and stalls againg? note I replace the fuel filter but did not...
If it is your security system you might want this, and please rate your mechanics help, Have a good day.
Vehicles effected
1997 or newer
1998 or newer
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (Radio Shack, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
2: Find the 3 wire ribbon cable, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
Oct 02, 2009 | 2000 Chevrolet Silverado
1999 won't start when security light is on.
If you would like to bypass the system I found this, Good luck and please rate your mechanics help.
Vehicles effected
1997 or newer
1998 or newer
Sep 26, 2009 | 1999 Pontiac Grand Am GT
Was wondering how to disable passlock on my 99 chevy silverado?
Go to bulldogsecurity.com on the left there is info on bypass security systems it tells you to go to a web site and purchase a bypass module
Mar 03, 2009 | 1999 Chevrolet Silverado 1500
Ignition passlock sensor
have a great day.
Vehicles effected
1997 or newer
1998 or newer
Feb 24, 2009 | 1998 Pontiac Sunfire
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
