Question about Dryers
The dryer has worked fine for several years, but now it pops the GFI circuit with a full load. Taking out about half the load usually solves the problem. We recently cleaned the lint out of the duct, so that is not the problem.
  • 1 more comment
  • docwriter May 08, 2009
    Thanks. I didn't think about the GFI receptacle being faulty, but of course it can be. I had a problem with another GFI installed at about the same time, so I'm going to replace the GFI receptacle and see if that will solve the problem.
  • docwriter May 09, 2009
    I replaced the GFCI outlet, put a full load in the dyer, and the GFCI popped. Took out about 2/3 of the load, reset the GFCI, and started the dryer and it is now running beautifully. So, it would appear that the problem is in the dryer and is in some way related to the size of the load. Any suggestions?
  • docwriter May 27, 2009
    Hi Rylee,
    I replaced the GFCI receptacle with a standard one and the problem went away. Full loads have not popped the circuit breaker.
    Thanks for your help.
    Brigadier General:
  • 8,619 Answers
Hi
GFI circuit blows as the dryer overloads the circuit and the breaker did not trips fast enough. Try changing the breaker and also check for the burnt wiring between the GFI and the panel. The cause is either a short circuit in the dryer or a worn-out GFI outlet. To determine the culprit, follow these troubleshooting steps-
Plug the dryer into another GFI outlet in another location. If that GFI also trips, the dryer is at fault and should be replaced. If the dryer runs normally, that GFI outlet is faulty and should be replaced. And check they should be 20amps and not 15 amps.
Please note that GFI circuits are needed only when --
1) The laundry recepetacle for the dryer cannot be shared with other rooms or loads.
2) You do not want the washer on a GFI. Unless there is a laundry sink within 6' of the receptacle.
Please see this link for more details on GFI circuits---
GFI circuits Troubleshooting
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 08, 2009
  • Rylee Smith
    Rylee Smith May 08, 2009
    Please do check and confirm if that solved your problem.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith May 10, 2009
    Hi
    You'll need to look for a shorted or cut wire inside your dryer. Also check if there is any moisture on the wires inside the dryer. And if on heavy load it blows the circuit then either its your motor whose winding are shorted. Secondly, if your dryer is electric, then the heating elements are on the way out as they are requiring more energy to do the job they were intended for and thats why blowing the GFCI circuit.
    Thanks
    Rylee
Ge 50amp gfci trips, worked great before I bought it
Hi hondo,
When an electric motor kicks on there is an in rush current called FLA(full load amps), it is usually about 125% of rated circuit amperage. Try a 2 pole 60 amp gfci circuit breaker and see if that solves your issue. Going up to this amp breaker will not be a fire hazard or cause any anomalies.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 19, 2008 | Spa Parts Plus GFCI, Circuit Breaker, 40...
GE UNDER COUNTER ICEMAKER HAS BEEN GREAT FOR THREE YEARS, NOW POPS THE GFI DURING CYCLE. TECH SAYS IT SHOULD NOT BE ON GFI CIRCUIT.WHY IS SO AFTER THREE YEARS/
Good chance your Gfi is on verge of failure I had one, took long time for me, yes me to figure it out. Replacement may solve problem. Double check, have you added other appliances on the same circuit? GFI will pop when other appliances are on the same circuit. For example two coffee makers on same time same GFI and similar issues. Otherwise may have a problem with the ice maker voltage leaking somewhere. If GFI replacement doesn't help. Do you still have warranty on Icemaker? If so follow that. If not contact Ge anyway. Recalls maybe "hidden".
Feb 27, 2015 | GE Refrigerators
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
My dryer will only work for like 3 minutes and then it kicks out the breaker. It is an lg tromm dle3777w. It has worked fine for about 4 years. Used it for a load already today and it worked fine. ...
Hi - there is a fault with the heating circuit, most likely either a bad connection on the elements or elsewhere on the wiring. The only other problem would be the actual heater element, although doubtful as it would normally pop the circuit breaker instantly if this was the case.
Although i'm not familiar with this particular model all dryers operate the same way, when on air dry there is usually no heating involved, it will work ok.
If you can handle the repairs yourself otherwise get an electrician or appliance serviceman to help you out.
Jun 15, 2011 | Dryers
Main main breaker keeps popping after I put in a pond lite and run the electric dryer. Could this be a ground problem or what else it just started
How about disconnecting your pond lite, and then trying your dryer? Usually pond lights are wired with some sort of ground fault protection. And this will trip immediately if there's another source...especially a heating source with a motor. Its the motor that senses the gfi, and trips it. I'd disconnect the pond light from the dryer, and then try it. If it works fine, then get another power source (not linked to the dryer) to run the pond light and see how it works. I believe when you separate their power sources, you should be fine. Try this, and then let me know if you have success, or need some more guidance. But I'm most sure this is it. Good Luck, and I hope this works for you. - Jim
May 05, 2010 | Solar 200 Amp Murray Mda 2200 Main Circuit...
Washing Machine Pops GFI Circuit
I agree. could be heater or motor..try disconnecting one wire on heater then trying if still same try unplugging motor plug ...this will say which one..please leave feedback..
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Drying time on aquarius vtd20
The timer is an electro/\mechanical one , and is usually non repairable, the only thing you can do short of replacing it, is to remove the top cover, and clean away any fluff or dust that you can see, and spray inside the the unit with wd 40.
If this does not solve the prob, then you will have replace the timer complete.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
Dryers Logo
61 people viewed this question
Top Dryers Experts
