Question about Amana ASD2620HRZ Side by Side Refrigerator
TIGHTEN DOOR HANDLES MODEL ASD262OHRZ SIDE BY SIDE
4 Suggested Answers
SOURCE: bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Posted on Jan 19, 2009
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
  • 291 Answers
SOURCE: The freezer handle is loose on one side. How can
Check to see if your freezer handle has an inlay in the handle or trim that pops off to get at a screw that holds the handle onto the door. If you don't have this then you may have a handle that literally slides up and off. You then tighten the mounting screws or replace the handle if that is what is making it loose. We no longer can tear apart the doors on refrigerators to get at components inside, because the factory puts these together and shoots liquid insulation into the cavity, and this insulation expands and hardens making it impossible to tear doors apart anymore. This is why most handles now are front repairable. Good Luck. Appliance Specialists
Posted on Dec 11, 2009
Testimonial: "Excellent advice! The picture attached really helped make it clear."
I have the Frigidaire Model BFHS2611LMO Side by Side and the handle on the right side is very loose. I took off the rubber seal on inside of door but dont see any screws to tighten. How do I tighten
The model number is actually BFHS2611LM0. The handles have keyhole openings that fit over the pair of screws (near the top and bottom of the handle) on the outside of the doors. Try pushing the right side handle forward and down to lock it back onto those screws. If that doesn't solve the problem, push the handle up and then lift it off the screws. Then tighten the screws a bit (or replace them if they have stripped threads). Then replace the handle over the screws and push the handle down. Do not overtighten the screws; that can damage the door components. The manuals is available from Frigidaire's support site: http://b2b.frigidaire.com/support/manuals.asp . The support page for your refrigerator is here: http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=BFHS2611LM0&User=&Search=Search . The parts diagram shows how the handles are attached; it's the last link on the support page.
I hope this helps.
(please replace the door seal properly to ensure that your refrigerator maintains it's efficiency. http://www.searspartsdirect.com/frigidaire-refrigerator-parts/model-BFHS2611LM0/1428/0165000.html has another copy of the parts diagrams with the parts for sale.)
Jul 28, 2015 | Frigidaire Refrigerators
Tighten door handle on Whirlpool Conquest refrigerator
You need to remove the handle befor eyou can tighten the mounting bolt behind it. T remove the handle just grab it and yank UP quick and hard. The handle will unclip and release, then you can tighten the bolt down and re-install the handle.
How strong do you have to be?!!! Trying that and it won\'t unclip. Not sure how hard to try--or will you break something?!!
You have to pull up pretty darn hard with a jerk. That is how both handles are removed on these conquest refrigerators
Sep 01, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
The handle on my refrigerator door (Admiral side by side model LSD2615HEZ) is loose. How do you tighten the handle?
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Dec 30, 2009 | Refrigerators
Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Feb 24, 2009 | Admiral 26 cu. ft. Side-By-Side...
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
