Question about Kenmore 54501 Dehumidifier
On the back of the machine there is a plastic tube/pipe that has threads on it and my pale inside is not filling up instead the dehumidifier is sitting on a five gallon bucket leaking into another pale what is my problem? I want the water to drain into the pale not outside!?
  • Samuel Charles Spriggs May 11, 2010
    Something is clogged not allowing the water to drain into the bottom of the dehumidifier (or not allowing it to drain from the dehumidifier pan). Are you sure there is no water in the boytom pan in the dehumidifier -- usually the inside pan fills up and runs over.
  • 148 Answers
Cracked or loose lokk at where the adapter comes out make sure it is tight and also not blocked
Posted on May 10, 2009
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
I don't know where the pipe connects to the dehumidifier, the threaded pipe which will bypass the collection bucket. I inherited the unit (sans manual) from my sailor son who used it in his boat.
Jeremy, you will either find it on the back of the unit. It will have a screw off plastic cap on the connection. OR when you remove the water bucket, you will see it inside that cavity, that the bucket is insert into. In both cases, it will look like a garden hose connection. The hose you attach, should not be longer than 5 feet. It relies entirely on gravity to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | LG LHD659EBL Dehumidifier
I have a lg lhd45elt8 dehumidifier i bought used i want to hook up the hose connection i see on the back a plastic chip that needs to be removed and the hose pipe is just inserted? then connect a drain...
I own this dehumidifier. To connect it to a garden hose for drainage you first need the special connector pipe/adapter that comes with the unit. It's white plastic and about a foot long, It may be stored in the top of the bucket drawer, where it ships from the factory. Your hose connects to the threaded fitting on one end. The other end is inserted into the hole in the back of the unit. You slide it straight in until it mates with a drain connection inside the unit. You can see this black pipe connection if you pull the bucket drawer all the way out and look in the very top right hand corner of the opening of the unit. Once the white tube is fully and correctly inserted you'll find two plastic tabs on the tube near the hose connection. The larger tab points straight up and blocks the tube from being inserted too far. The smaller tab points down and hooks into the slot in the bottom of the round opening to keep it from getting knocked loose. Your dehumidifier should now drain through the hose instead of into the bucket. Of course, be sure your hose is routed across a floor to a drain or sump pump located lower than the unit, since the water flows by gravity.
Apr 27, 2011 | LG LHD45EL Dehumidifier
Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
May 04, 2010 | Whirlpool AD50USS Dehumidifier
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Water from LG 30 pt dehumidifier drains into reservoir instead of running through garden hose into floor drain like it is supposed to. Have checked...no obstructions to garden hose. Very frustrating...must...
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Jun 19, 2009 | LG DH30 GoldStar Dehumidifier
I purchased a LG Dehumidifier MODEL LHD45EL and I followed instructions to attach a hose to it for the drain. I removed the drain hole cover and I don't see a drain hole connector or a hole to install it...
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Jul 22, 2008 | Maytag M7DH45B2A Dehumidifier
Connection for continuous discharge
There unit should have come with a small plastic tube. One end should have a thread connecion for hose hook-up. There should be an opening on the back of the unit that you push the tube through to connect with a little elbow tube inside the unit. You should be able to see the elbow connector from the front of the unit by removing the water bucket. Just push the plastic tube in from the back until it fits snuggly over or into the elbow tube and replace the water bucket. Run the connected hose to your sump pump.
Jul 16, 2008 | Dehumidifiers
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Push through the membrane with the drain connector. The membrane has a circular cut almost all the way through it, and pushing at it with the drain connector will pop out the little hole. I've done it with four LG units.
Sep 06, 2007 | LG DH30 GoldStar Dehumidifier
Kenmore 54501 Dehumidifier Logo
380 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
