Avion ceiling fan manual... wasn't in box model c52-f
SOURCE: installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Posted on Aug 21, 2009
  • 34 Answers
SOURCE: I have a Hamptom Bay ceiling fan model number EF200D
home depot sells universal ceiling fan brackets for a few dollars, they will be near the lamp parts
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Posted on Sep 10, 2009
  • 760 Answers
SOURCE: I wish to install a ceiling fan in my bedroom.
a celing fan should only be mounted on a box rated for a ceiling fan. This is a NEC code requirement. You could remove your existing box, and install a new box rated for a ceiling fan. You install the adjustable cross bar, and then attach the box to it. It also has stronger threaded inserts for the fan attaching bolts. Better than having a fan flying through the room.
Posted on Jul 25, 2010
SOURCE: need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Posted on Oct 10, 2010
  • 4736 Answers
SOURCE: The remote on my Hunter
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Posted on Jul 25, 2011
Where can I find a reciever for my Avion ceiling fan
Who makes this fan? I've never heard of this model.
Oct 09, 2014 | Dryers
I wasn to install hampton bay ceiling model 161646 on slanted roof
Buy a longer rod at Home Depot. Should really avoid store brand fans if you want a good fan.
Jan 20, 2014 | Hampton Bay 24002 Ceiling Fan
Avion ceiling fan
Did you check the old bulb in another lamp or check the new bulb in the fan yet. The light has a it own switch and you gotta access it's wiring to it to check it out.
Sep 10, 2013 | Heating & Cooling
How can I find the model number for the fan. I have a 1999 avion with a coleman mach air the fan makes a lot of noise.we oil it but it quit last night and I think it may need replacing.
The model number of you upper unit which can be seen from inside on bottom of unit behind filter etc at ceiling, will give enough info for replacement fan. Here's a good spot to find part #'s etc for your unit.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Aug 20, 2011 | Coleman Mach III Air Conditioner
Do you have free manuals for a hampton bay ceiling fan model 52 rdt?
http://www.homedepot.com/catalog/pdfimages/c6/c640c29e-5efd-4045-be74-016e88d7e04b.pdf
According to Home Depot this is the Hampton Bay manual for that model number.
Indicated here: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10051&catalogId=10053&productId=100032172&R=100032172
Excerpt:
  • MFG Brand Name : Hampton Bay
  • MFG Model # : HD302243
  • MFG Part # : YG092-VPW
Jun 05, 2011 | Hampton Bay YG092-VPW 52'' Preston Vintage...
I have a westinghouse ceiling fan model 78622, where do i find a wiring manual for this. I have connected up the fan in place of an old one that was taken down, the wiring seemed straight forward but only...
If you have only a black and white (and bare ground wire) in the ceiling box where the old fan was connected before, you should connect both the blue and black wires from the fan to the Black (common) wire in the ceiling box.
Then connect the white wire from the fan to the white (neutral) wire in the box together. Connect the green and bare wires together (Ground wires) and the fan and light should function with the pull chains as designed.
IF you have a wall switch for the ceiling fan and a separate one for the light, it is simply a matter of making the connections for the light and fan to the proper wires going to the wall switch box. Typically, the ceiling fan's light wire (blue in most cases) is connected to the red wire in the ceiling box, while the fan wire (black in most cases) is connected to the black wire in the ceiling box. Connect the white wires together; and then the green and bare wires together for your ground and you should be set.
Remember to disconnect the power to this circuit by turning off the breaker before doing any wiring work.
I hope you find this Very Helpful and best regards!
Oct 11, 2009 | Dryers
Installaion manual for ceiling fan
Dec 03, 2008 | Aloha Housewares (93645) Ceiling Fan
Aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
Aug 02, 2008 | Aloha Housewares (93645) Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
