Question about HP PSC 1510 All-In-One InkJet Printer
Printer When I click print, my printer spits out 2-3 pages before it finally begins printing. I am printing on ink jet T-shirt transfer paper
I am using th eHP PSC 1510 All-in-One Ink Jet Printer and its software.  It doesn't do this on Word documents.
Posted on Oct 15, 2007
    Scholar:
  • 116 Answers
What printer and software are you using?
Does it do this for anything you print. Example a word document.
Posted on Oct 10, 2007
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
My samsung CLX2160N keeps printing with no ink on the pages and even though I print one page it just keeps spitting paper..also the green drum in the printer appears to be covered in black ink
If the toner is not empty and you notice that the toner assembly is dirty with print dust, then it probably is an issue of transfer corona failure. You will have to replace the entire printing mechanism. But before you go out and cash out over $200 for the new assembly it's best that you take the printer back to the shop where you purchased it. The print assembly warrants over 50.000 printouts, and if you haven't printed out so much it may still be under factory warranty.
If you haven't used the printer too much (never replaced toners, never printed out over 500 pages total) then there's an easy way to verify if the transfer corona is really the problem. Pull out the print assembly and check to see if the waste toner tank is full/overfilled. If it is brimm-full then you're definitely facing a bad transfer corona and you will have to replace the entire mechanism, or find a good repair technician that can fix the existing one.
Another possibility would be if there is some dust on the paper and you can see some of the print powder on the exit tray. If there is print dust on the exit tray that means that the fuser is not working. If the papers that are coming out of the printer are cold then this is deffinitely a fuser failure, and you're still stuck with either repairing the print assembly or cashing out for a new one.
About the problem with the printer spilling out paper all the time, see if you've set the printer to print A4/Letter size printouts or it's set to print infinite paper track (like those old paper formats we see on old 80's movies). Either way, the no print and the paper spitting are not related issues.
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
Printer spits out blank paper....it does not print. We have replaced all the ink cartridges to make sure we have ink.
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Nov 10, 2010 | Brother MFC-5440CN All-In-One InkJet...
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Brother printer taking too long to eject a printout
I'm not sure I understand your question. It sounds to me like the printer is working properly. An inkjet will spit a text only page out faster than a page with graphic data on it.
Ink Jets print the images in a "Swath" pattern. This is what gives the page the step motion on exiting a printer.
Now laser printers, since they are intelligent printers, will build an image and then transfer the image, fuse the image and eject the page in one smooth operation.
But lasers would require a "Print Page" command from the datastream to force the page ejection or trying to print outside of the no print area on the page.
For example a PCL 5e datastream would issue a hex 0x0C command to eject the page.
PostScript wouold issue a "Showpage" command.
Don
Jan 29, 2010 | Brother MFC 4650 All-In-One Laser Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
