Question about GPS
RouteSmart NDrive 9.2.39 gps stopped communicating with the maps
RouteSmart NDrive 9.2.39 gps has comunication with the satelites but does not communicate with the map programs
  • 10 Answers
SOURCE: Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Posted on Oct 04, 2007
djnick989
  • 1067 Answers
SOURCE: I have lost my Mapsource Setup cd for my Garmin GPS
  1. Download MapSource software updater from Garmin. The version as of December 4, 2007 is 6.13.6, and the trick also works on Map Source version 6.13.5.
  2. Unpack or extract the content of MapSource_6136.exe
    downloaded using WinRAR.
  3. From the extracted files, run MAIN.msi.
  4. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
  5. Garmin MapSource now installed.
Posted on Feb 02, 2008
  • 3 Answers
SOURCE: navman maps , loading new maps through windows vista ??????????
I just had same problem while trying to load 2008 maps onto N40i . This I unfortunately discovered once I had already removed the existing maps as instructed part of install.
SmartST2006 isn't so smart! It kept saying I wasn't connected to internet when it was registering my product key' despite it most definitely being connected and I had temporarily disabled my AVG firewall just in case it was blocking.
I found an alternative way of registering the maps on the Navman website where it is required to enter the Navman serial number and the maps product key in order to get a code but that didn't work for me either, it didn't recognise my Navman serial despite having been fully registered when new.
My final (desperate) solution worked - find a computer with Win XP install SmartST2006 and hey presto! It took quite a while to load the maps though.
Proof to me that SmartST2006 is not compatible with Vista, if only they had put a slip in the maps box warning of this possibility.
The 'latest' pan Europe maps which are labeled 0408 actually appear to be 1106
Posted on Nov 28, 2008
  • 31 Answers
SOURCE: Garmin 405 - cant unlock maps
Step 1: Get "garmin_keygen_v1.5.exe" 2008 by JetMouse
Step 2: Follow the bottom instructions...
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Enter the type of map you're using or if you have the Map ID enter in a custom map, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: magellan sportrak color map problem
DOWNLOAD A FREE USER MANUAL AT
http://www.magellangps.com/assets/manuals/SporTrak_series_en.pdf
.....COINWAGON
Posted on Mar 31, 2009
Como usar mi gps ndrive ?? no entiendo nada donde
Hola, en el siguiente enlace hay tutoriales de video de como usar los productos ndrive, por el momento solo estan disponbles en ingles, pero con estos tutoriales puede ser mas facil aprender el uso del equipo: http://www.ndrive.com/en/pages/customercare#
Mar 02, 2011 | GPS
Yeah, I wish. Having bought an NDrive Touch XL SE sat-nav, only to find it went faulty after a version upgrade download, I now don't have it. After NDrive emailed me zipped files for installing, the thing...
I purchased an Ndrive Touch as well from CTC. It too froze on me after upgrading to the software.
Customer service is non existant in the Ndrive corporation. I found that the units were experiencing problems due to software/hardware incompatiblilty. The underlying message......NDRIVE is purely garbage. Absolutely NO customer support.
Feb 22, 2011 | GPS
Download new maps, I dont have a comunication cable? what now
Put the maps on the SD Card or buy a cable, the cable is a standard mini-usb.
Nov 17, 2010 | Garmin nuvi 200W GPS Receiver
I have a ADV3500PC touch screen with built in GPS. I have installed nroute, Gpsgate, mapsource with Gamap SAS Topo NNT 2010.01. Nroute displays searching for Satellites but does not find Satellites. Any...
There is a possibility that the antenna is defective. Sometimes a factory reboot helps or re-burn of the firmware. One way to confirm an antenna problem is to go into the tools menu and select "about". If the screen says "GPS S/W = 0.0 (should be a real number like 2.9 or 3.0) then this indicates that your antenna is not communicating with the main board.In this case, you need to send the unit to the manufacturer.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 15, 2010 | Garmin GPS
TomTom One has lost connection with satilet
To regain connection back to th satelite, first remove it and reinstall it back, if it does not connect still, then you have to update the tom tom reciever by connecting it to a computer, remove all the maps on it, the update it from the home website.
After updating, upload the new maps back on it, the you connect it to the car system, after doing this, then you try to use it. If it does the same, then it is due to a poor signal in the area that the gps in not connecting to the satelite.
Take care
Sep 09, 2010 | Tomtom ONE GPS Receiver
My garmin nuvi 255w was bought in april 2009, now it often lost satelites while i'm driving, some times it lost satelites for more than half an hour so cannot be functioned properly; more so, it often...
You can update the software at no charge from Garmin. Get a mini USB cable, connect the Nuvi to your PC, go to Garmin.com.
The software updates are free, maps cost!
Apr 04, 2010 | Garmin nuvi 255W GPS Receiver
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
The Map on my magellan program is wrong, I have satalite photos of a waterway, i am planning on taking a tirp on, but the map on my gps isnt correct, what can i do??
oh i got it. it's because of the map overlays right?
open the satelite photo on the computer with notepad and edit the correct latittude and longittute
i think that the first line is for up left corner 2nd line is for the up right corner and ex.
May 03, 2009 | Magellan SporTrak Map GPS Receiver
Magellan Maestro 3100
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Maps and POI's are gone
You can try a Master Reset, but be aware, this will ERASE ALL OF YOUR FAVORITES. To do a master reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but continue to press the screen until the unit asks if you are sure you want to reset. Press yes. This MAY help.
Oct 12, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
21 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
