Can the Dometic 3107541.009 relay control be replaced with 3109226.005 relay control
Can you replace Dometic 3107541.009 analog control unit with Dometic 3313192.000 digital control unit?
e-mail or call dometic support : (www.dometicusa.com) and make sure you give them the model # of your control box at ceiling assy and they will tell you if they will work together.
Jul 30, 2014 | Dometic 3107541.009 Analog Thermostat...
Relay board
sounds like when compressor starts it loading down voltage. replace capacitors.
Sep 16, 2013 | Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Have a dometic refridgerator in a Freighliner truck,cools down then warms up,runs then shuts off for 2 seconds then restarts, flashing red light 3 times then pause then repeats,product # 921047460 , mfg #...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 20, 2011 | Dometic Refrigerators
Have dometic model rm2862 in rv camper. Woke up this morning and it is not working. No lights, no power, nothing! Took the outside cover off and could smell an amonia odor.
NOTE: This
Leo Ponder
Sep 08, 2011 | Dometic Refrigerators
Can I use a refrigerator on electric only if it developed a leak on the boiler tube
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Dometic Refrigerators
The dometic roof ac humms when rv is on 110 ac unit was under warranty dometic sent a complete control board I changed control and stil have problem just like before. Dometic said one of the relays was...
not likely but possible. if they already had one bad board what's to say their production methods have changed since they made your last bad board. I have just had 6 bad compressors from this chinese company danfoss in one month! for only 2 freezers i have installed 3 bad compressors in each! nobody takes pride in production anymore they want the stuff to break.
Oct 10, 2009 | Dometic Rooftop RV Air Conditioner
Roof a/c unit clicks when wall thermostat is adjusted but wont come on?
no ac power you are hearing a 12 volt relay tellling it to come on but there is either no ac power or control ac relay is bad and you will have to replace control unit to ac useually arond 150 depening on unit
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Dometic roof air
Sounds like the unit either has been miswired from the beginning or there is a stuck contactor relay.
The more rare scenario is that the control wire between the t-stat and the contactor is shorting to a power source causing the relay to energize. Good Luck!
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
