Question about Dometic Heating & Cooling
Can the 3107541.009 Relay Control be replaced with 3109226.005 relay control?
SOURCE: ac compressor wont go on
ac compresor relay diagram/scamatic
Posted on Sep 06, 2008
motor1258
  • 6674 Answers
SOURCE: 1998 plymouth grand voyager cruise control relay/fuse location?
Check under hood in box marked fuses & relay, on drivers side and look under cover of it for I.D.
Posted on Apr 11, 2009
bobicehouse
  • 1524 Answers
SOURCE: Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Posted on Apr 26, 2009
AnIdea
  • 33 Answers
SOURCE: A/C Control Relay
There are several relays for the A/C system on these. Using the reverse of the lid of the fuse/relay plate box it will show you the positioning of the relays but not the description;
I've added in the description so hopefully will help you!
Relay 9 - Heater blower relay
Relay 10 - Heated rear window relay
Relay 13 - A/C condenser blower motor relay
Relay 14 - A/C compressor clutch relay
Relay 15 - A/C condenser blower motor relay
There is no relay itself for the A/C control, however there are a couple of fuses for this. If you need I can supply you with the fuse position and exact function within the AC system.
Out of curiousity whats the problem with your AC?
Hope this helps
Posted on May 28, 2009
  • 55 Answers
SOURCE: 2005 yam r6 fan control relay location for manual fan switch
The fan is controlled from stat on side of radiator. Take the plug off stat and wire your switch in to it
Posted on Oct 11, 2009
What does F6 error code for Whirlpool microwave model XCK4640802 mean
The F6 code is listed as a problem with the MW relay. Here are the testing steps from the technical literature. The relay that is mentioned is a part of the control so if the problem continues you will need to replace the control.
1. Unplug microwave oven or disconnect power.
2.Check the cable to Relay 4903.
3. Check to see if the relay (4903 on relay electronic control) contact has welded closed.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
6. If problem persists, unplug microwave oven or disconnect power.
7. Replace electronic control.
8. Replace all parts and panels before operating.
9. Plug in microwave oven or reconnect power.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Whirlpool Microwave Ovens
2003 Cadillac coupe DeVille . Diagnostic code RIM C0655. Where do I start?
DTC C0655
Level Control Compressor Relay Malfunction .
You start by doing the diagnostic tests for that code .
Circuit Description
The automatic level control adjusts the vehicle suspension ride height. The RIM determines the height of the vehicle based on the voltage from the automatic level control sensor. The RIM grounds the compressor relay and the exhaust control solenoid to raise and lower the vehicle in order to keep the vehicle level.
Diagnostic Aids
• Inspect all wiring harnesses carefully for chaffs and proper routing. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
• This circuit is monitored before every functional operation of the compressor relay output. If a compressor relay fault is detected, the RIM retries the output every 15 seconds to try to recover from the fault.
Your probably not going to be able to do the factory diagnostics unless you have a factory scan tool to turn on an off the relay . You can test with a volt meter at the relay for B+ voltage and control from the RIM - Rear Integration Body Control Module. Do you know what a relay is and how it works ?
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, command the level control compressor relay ON and OFF.
Does the level control compressor relay turn ON and OFF with each command?
YES Go to Diagnostic Aids
NO Go to Step 3
Turn OFF the ignition.
Disconnect the level control compressor relay .
Probe the coil side feed circuit of the level control compressor relay with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
YES Go to Step 4
NO Go to Step 10
Connect a test lamp between the control circuit of the level control relay and the coil side feed circuit of the level control compressor relay.
With a scan tool, command the level control compressor relay ON and OFF .
Does the test lamp turn ON and OFF with each command?
YES Go to Step 8
NO Go to Step 5
5
Does the test lamp remain illuminated with each command?
YES Go to Step 7
NO Go to Step 6
6
Test the control circuit of the level control compressor relay for a short to voltage or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES Go to Step 13
NO Go to Step 9
7
Test the control circuit of the level control compressor relay for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES Go to Step 13
NO Go to Step 9
8
Inspect for poor connections at the level control compressor relay . Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES Go to Step 13
NO Go to Step 11
9
Inspect for poor connections at the harness connector of the RIM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES Go to Step 13
NO Go to Step 12
10
Repair the coil side feed circuit of the level control compressor relay . Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
YES Go to Step 13
11
Replace the level control compressor relay.
Did you complete the replacement?
YES Go to Step 13
12
Replace the RIM. Refer to Rear Integration Body Control Module Replacement in Body Control System.
YES Go to Step 13
13
Use the scan tool in order to clear the DTCs .
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Aug 04, 2017 | Cadillac Cars & Trucks
How do I fix the horn on 2006 Impala
System Description
The horn PCB relay is non replaceable ,soldered to the underhood fuse / relay box. . You would have to take the box a part to get at it . Is the air bag light lit on the instrument cluster ? Could have an open wire in the Clock spring , do you know what a clock spring is ? It is inside the upper part of the steering column , It allows the steering wheel to be turned full right to full left keeping the horn an all the buttons an air bag connected electrically. When the horn button is pressed, ground is applied through the horn switch contacts and the horn relay control circuit to the coil side of the relay. The horn relay coil is then energized, causing the relay switch contacts to close applying voltage through the horn control circuit to the horns. For theft deterrent functions, the body control module (BCM) also controls the horn relay by applying ground to the relay control circuit to the relay.
Circuit/System Testing
With a test lamp connected to ground, probe each of the test points on the HORN fuse while activating the horns. The test lamp should illuminate at one or both of the fuse test points.
If the test lamp does not illuminate at either test point, refer to the Horn Switch Test.
If the test lamp illuminates, refer to the Horn Test.
Ignition OFF, disconnect the inline harness connector C275. Ignition ON, test for B+ between the horn relay control circuit terminal B and ground.
If less than B+, test the control circuit for an open/high resistance. If the circuit tests normal, replace the underhood fuse block.
Momentarily connect a 3-A fused jumper wire between the control circuit terminal B and ground. The horns should work.
If the horns do not work, replace the underhood fuse block.
If all circuits test normal, test or replace the horn switch
The PCB relay horn system consists of the following components:
Horn switch
Horn PCB relay
Horn assembly
Body control module (BCM)
HORN fuse 15 A
How cars clock spring works
May 17, 2016 | 2006 Chevrolet Impala
Whats the codes p0685 an p0688 on a 2004 chrysler pacifica mean
P0685 CHRYSLER - Auto Shutdown Relay Control Circuit Failure
Short or open in Auto Shutdown (ASD) relay circuit
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible Causes
- ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech Notes
Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
P0688 CHRYSLER - Auto Shutdown Relay Control Circuit Low
The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Symptoms
Possible Causes
- Failed ECM
Tech Notes
Dec 29, 2014 | 2004 Chrysler Pacifica
Audi fault code 17072
Possible Symptoms
  • Engine Coolant Fan running at full Speed while Ignition is OFF and Engine is COLD (could lead to discharged Battery)
Possible Causes
  • Fuse(s) faulty
  • Power Supply Relay for Engine Control Module (J271) faulty
    • Terminal 87 faulty/hanging
  • Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271) faulty
Possible Solutions
  • Check/Replace Power Supply Relay for Engine Control Module (J271)
  • Check Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271)
  • Check/Replace Engine Control Module (J220)
(See http://store.ross-tech.com/shop They sell a very useful tool for diagnosing Audis)
Jan 25, 2014 | 2003 Audi A4
What does the code P1765 refer to
Symptom:
P-1765 TRANSMISSION 12V SUPPLY RELAY CONTROL CIRCUIT
When Monitored and Set Condition:
When Monitored: Continuously with the key on.
Set Condition: This code is set if the voltage detected on the Transmission Relay Control
Circuit at the PCM is different than the expected voltage for 3 seconds.
POSSIBLE CAUSES
NO POSSIBLE CAUSES REMAINING
GENERATOR SOURCE CIRCUIT OPEN
TRANSMISSION CONTROL RELAY DEFECTIVE
TRANSMISSION CONTROL RELAY WIR INTERMITTENT DEF
TRANSMISSION CONTROL RELAY WIRING OBSERVABLE DEF
TRANSMISSION RELAY CONTROL CIRCUIT OPEN
TRANSMISSION RELAY CONTROL CKT SHORTED TO GROUND
POWERTRAIN CONTROL MODULE DEFECTIVE
Feb 03, 2012 | 1999 Dodge Dakota
Diagnostic code for my 2007 saturn ion says p0480 cooling fan 1 control circuit malfunction. what does this mean.
WHAT IT MEANS YOUR FAN CONTROL RELAY CONTROL CIRCUIT IS OPEN OR SHORTED TO GROUND. FAN CONTROL RELAY CONTROL CIRCUIT IS SHORTED TO SYSTEM POWER. THE FAN CONTROL RELAY POWER CIRCUIT IS OPEN CHECK COOL FAN 1 FUSE. FAN CONTROL RELAY IS DAMAGED OR HAS FAILED. PCM HAS FAILED.I LISTED ALL POSSIBLE CAUSES TO CODE PO480.
Jul 05, 2011 | Saturn Ion Cars & Trucks
How do i test my fuel pump relay i think it is bad ? 92 chevy 1500 4x4 V8 5.0
Hi, to test your fuel pump relay, unplug the relay, identify the two control circuit terminals and the two power circuit terminals. Most relays have a diagram printed on the case itself to identify these terminals. If not, look at the mounting base of the relay. The two thin-gauge wires that connect to the relay feed the control circuit terminals; the other two thick-gauge wires connect to the power terminals. Test for continuity between the two power terminals on the relay. Using an ohmmeter, set it at the lowest resistance range and touch the meter leads to each of the relay power terminals. You should read infinite resistance; otherwise, the contact points are shorted. If this is the case, replace the relay. Connect the end of a fused jumper wire to the positive terminal of the car battery and the other end to one of the control circuit terminals on the relay. Hook the end of a regular jumper wire to the other control terminal and touch the other end of the jumper wire to a good ground on your vehicle (this could be the engine block itself). As you touch ground with the wire, the relay should make a clicking sound. If not, swap the jumper wire connections. If you still cannot hear the click sound, the relay is shorted. Replace the relay. Leave the jumper wires connected to the relay control terminals and test the power terminals for continuity as you did in step 4. This time you should read zero or a resistance value in the hundredths or thousandths. If you read infinite resistance, replace the relay.
Jun 11, 2011 | Chevrolet 1500 Cars & Trucks
Kenmore elite dryer 11063942101 works if I force the switch to stay in the on position but won't start by just pressing the switch. Replaced pust-to-start switch. Same problem. Vacuuming out the areas...
The problem is definitely not the motor but rather the motor relay or the electronic control. Either the motor relay is not working to close the motor circuit or the electronic control is not powering up the motor relay to serve its function.
The motor relay and the heater relay are identical and can be used interchangeably. The heater relay may be used in place of the motor relay if the dryer heats up when the start switch is held on. It indicates that the heater relay is working.
Disconnect power to the dryer then pull the end cap trims off then remove the control panel securing screws. Once the screws are removed, rotate the control panel up to the rear of the dryer.
Disconnect the wires and remove the relays then put each in the place of the other. Refer to the component layout diagram for the location of the relays.
Reconnect the wires then rotate the control panel down back into position then plug the dryer in and start it. The dryer should start and continue to run when the start switch is released since the working heater relay is used but will not heat up indicating that the motor relay is not working. Otherwise the fault is in the electronic control.
Replace the faulty component and it should address the problem. The relay (heater/motor) is part number
3405281 and the electronic control is part number W10116565.
Squeeze on the electronic control mounting bracket as shown then pull the board up to remove.
Insert the new control board and gently press it down into position. Transfer the wires from the old board to the new board one at a time.
Simply unscrew the relay to be replaced then secure the new one into position and transfer the wires.
Rotate the control panel down and secure it back into position to complete the repair.
Aug 30, 2010 | Dryers
Whentrying to start it just clicks, has new battery this spring, checked 12.7 volts drops to 12 when at start, replaced control relay, no help. Can jump from output on control relay to solonoid control and...
So, it sounds like the contacts in the control relay are not passing current -- is this the conclusion you have reached?
Can you trace the hot wire on the coil side of the control relay back to anything -- this should eventually be coming (directly or indirectly) from the ignition switch.
Charlie
Aug 17, 2009 | Suzuki VS 1400 Intruder Motorcycles
Heating & Cooling Logo
46 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
