Question about HP Laserjet P4015x Printer
Data light blinks with nothing ever printing
After sending a job to print.. data light blinks green, but nothing ever comes out to print
  • 399 Answers
SOURCE: Paper light continually flashes won't print
when you lift the cover on the back of the printer there is a thin plastic sensor very delicate normally black in colour which detects whether there is paper in the tray or not.that sensor is slightly moved from its orignal position or broken , so this problem is coming.
thanks.
Posted on Sep 18, 2008
SOURCE: My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Posted on Nov 11, 2008
leroyal
  • 2120 Answers
SOURCE: HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Posted on Feb 26, 2009
  • 67 Answers
SOURCE: printer stopped working after I cancelled a print job
  1. Remove all print jobs at your computer
  2. Turn off printer
  3. Disconnect printer power supply
  4. Wait 30 seconds
  5. Reconnect printer power supply
  6. Turn on printer
  7. Try to print again, probably it will work now
Posted on May 06, 2009
  • 53 Answers
SOURCE: Catridge light and Data aresolid orange when machine turned on
This is a problem, sorry to say. The Mark Encoder is not being detected. In laymans terms this means that you need a new carrage. Part Number is C4713-60039. You also need to check on the condition of your belt at the same time. Is there somebody in your area that can do the work or are you capable ?
Dave
Posted on Jul 01, 2009
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
I have a Brother MFC-9120cn. when I send a test page the Green led /Data light flash but not print ever comes. I have reloaded drivers and firmware. It also say Offline and the is no print job in the...
If you send me an email to LBrown18062@hotmail.com, I will send you the user manual and the software installation guide. please put "brother mfc 9120 user and install" as the subject.
Sep 12, 2012 | Brother MFC-9120CN Multifunction LED...
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
When sending print jobs to the HP MFP 4730 device keep processing job and data led keep blinking with no printing
this problem comes due to formatter card it is faulty replacur problem will be resolvee them it will work ...........
Jun 17, 2010 | HP LaserJet 4730 MFP Printer
Data entry green light flashing. Users sending print jobs to the MP6000 are not finding their print job done. Print job history shows 0 jobs.
Make sure that a user code is not programmed in the copier itself. If it is programmed, the print driver on the computer must also contain the code.
this code can be entered in the properties menu under the "access" tab
Oct 14, 2009 | Ricoh Aficio MP1600SPF Copier
My green light is blinking and will not print
blinking green light -> Processing Data The printer is processing or receiving data - > To cancel the current job, press the CANCEL button
Oct 01, 2009 | HP LaserJet 1320 Printer
The exclamation sign flashes and then the green light but no printing
The service Manual says that if both the ready (Bulb) light and the exclamation light are both on it is a invalid engine
code /Invalid network code. But to clarify that you say they are both on and solid and not blinking. If they are you have a bad main board.
If they are blinking then the error is a Flushing /Resolution reduced error.
The cause is:
Printer is processing data or printing pages,but the resolution of a page in the current print job is reduced from 600 dots per inch (dpi) to 300 dpi to prevent a memory full error.
Solution is:
Wait until the ready light is displayed to print other jobs.
• Press and release the triangle button to cancel print job. It is the lower of the two buttons.
• Press and hold the traiangle button again to reset printer.
Hope this helps
Bruce
Jul 14, 2009 | Lexmark E232 Laser Printer
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
Feb 26, 2009 | HP LaserJet 4 plus Printer
"Printing" but nothing comes out......
Hey dear you did not describe the full detail. Light is continuously blinking and nothing is coming out from the printer OR printer is not printing anything. If the printer is not printing anyting and light continuously blinking. It means printer is not properly getting the data. You have to change the 'encoder' (a transparent strip goes through the carriage) and you have to clear the round transparent encoder present left side in the mechanical with wet cotton. After this your printer will work smoothly.
Sep 15, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP Laserjet P4015x Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
