Question about DeLonghi Heating & Cooling
Pac 35 split air conditioner not cooling
Hi i have a pac 35 split air conditioner wheni turn it on the fan runs but the compressor will not kick in.I tried turning the thermostat round fully but the compressor still did not run.
    President:
  • 1,489 Answers
Could be:
- low on refrigeraant
- loose/burned/corroded compressor electrical connections
- bad compressor run capacitor
- tripped/bad breaker in main service panel
- faulty controller components/relays
- other...
If you don't have significant experince with similar appliances/systems a service call is in order.
Posted on May 08, 2009
Why does our fan run but it is not cooling the room?
sounds like your compressor is not starting. Is this a split system? probable could be a run capacitor. Hard to say with out knowing what kind of system it is. Let me know and I will try to help you,
Aug 03, 2014 | Danby Heating & Cooling
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Oct 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mistral mss20 split a/c only cooling somtimes 4 about 10 m then
Sounds like your unit may be a bit short of refrigerant and the compressor is therefore cutting out on low pressure.
Jan 24, 2009 | LG Art Cool LA1000PR Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
My AC
One might think so, YES the compressor is running till it gets hot and tripps on hi-temperature, and after it cools down awhile, the switch willcautomatically reset itself and back- & forth......Thank-you-very much!
Jul 25, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
290 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
