Question about Sony Bravia 23" LCD TV KDL19M4000
Sony bravia lcd diginal kdl-19m400 audio doesn't work
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Posted on Nov 23, 2009
  • 51 Answers
SOURCE: I have a 42" Sony Bravia KDL-40S4100
Probable power supply
Posted on Dec 15, 2009
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia KDL-26L5000 no audio
Make sure you are plugged into the right audio input. They are not always the clearest with lableing those things.
Jan 19, 2013 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Volume control on sony bravia kdl-40v5100 is not working correctly. used to be fine around setting of 30 now at 50 to hear it
If you are using a Motorola cablebox, you may need to change the Audio in the cablebox to Heavy Compression. You can find this in the cablebox Menu, Setting, Audio. Set the audio to Advanced then change the compression.
Mar 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Nov 20, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Apr 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL-40S2000 "Bad LCD"
THERE ARE NO COMPONENTS TO BE REPLACED ON THE PANEL. THE PANEL MUST BE REPLACED.
Mar 06, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 23" LCD TV KDL19M4000 Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
