Aucma subwoofer - Audio Players & Recorders
Blue line onthe screen horizontally
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" or [line fault] of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 10, 2017 | Televison & Video
Tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jan 28, 2011 | Honda Civic Cars & Trucks
Tip
Car audio installation... important
when installing a sub woofer and amplifier to your vehicle always make sure that you also install a wired fuse in between your battery and amplifier without this problems may occur...
cheap subwoofer
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
on Jun 03, 2010 | Car Audio & Video
My Aucma Tvs menu is locked I can't access it what will I do
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Nov 15, 2016 | Televison & Video
I left my aucma tv on for a long time without use
Turn the TV off for awhile, maybe also unplug it and see if that helps.
Sep 18, 2014 | Televison & Video
Aucma tv
resert the remote control. take out the battery by 45 seconds and try again.However if you donot have success . Reload the code go
www.remotecodelist.com
God bless you
Jun 09, 2013 | Televison & Video
Aucma tv keeps blowing the capacitor near the flyback what could be the problem?
Check the regulated main power supply voltage. It might be more than normal.
Apr 07, 2012 | Akai Televison & Video
 Grubhead
Grubhead
