Question about Brother IntelliFAX 2800 Laser Fax
I changed the ink and the pages are still coming out with black stripes on them,can you help?
  • 46 Answers
You need a new PCU / drum unit are you using origional supplies ?
Posted on Jun 11, 2009
The CM2320nf printer has random 1/2" wide black
Really sounds like a defective cartridge or bad contact. Have you changed any of the toners recently? If so, try another cartridge of the color that you just changed.
Mar 16, 2011 | HP Laserjet CM2320nf All-In-One Color...
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Black stripe printing on the BACKS of the printed pages
This happens to me sometimes too, but randomly. I have found if I change it in properties to High quality printing that this disappears. Issue then is that more ink is used...check if you have it on fast print, or custom in the properties menu and try changing it....doesn't work all of the time, but has been helpful
May 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Apr 04, 2009 | Samsung CLP 300 Laser Printer
Kyocera FS-2000D is printing a grey stripe down the side of page
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer...........
Good Luck
Feb 16, 2009 | Kyocera FS-2000D Laser Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Problem with canon pi 4000
I think you have to clean the print head.and if cleaning doesn't help you may have to get a new print head.
May 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Broad light stripe down whole scan
Have you tried to do a cleaning of the color heads. Use a cotton swab, the same kind you use to clean your ears with rubbing alchy on it an clean the heads of the color injectors. If this dose not correct the problem then try changing out cartrages. IE if it is a grey stripe change out your black ink. If it is a pink stripe change out the color ink.
Apr 29, 2008 | Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
