Question about Dirt Devil Pd20000 Easy Steam Mop
Fix steam mop - Dirt Devil Pd20000 Easy Steam Mop
This is the third time--I need the directions
Go to Shark's website to find the manual to download.
Aug 08, 2015 | Shark S3601 PROFESSIONAL STEAM MOP
My steam mop heats but doesn't steam. almost every time I used it, I used distilled water
Try filling the tank with pure white vinegar and plug it in, pump the handle to get the vinegar through the hose and let it sit for a half hour to dissolve any gunk that is built up, CLR works well for this also. Once it has sat, empty the tank and fill with fresh water.
May 04, 2015 | Shark S3601 PROFESSIONAL STEAM MOP
Sunbeam instruction manuals
Hi! If your cleaner is not steaming it could be that the steamer pump is not on, or there is no water or not enough water in the tank. I have included a link to the instruction manual. If it is still not steaming please contact customer support at 1-800-321-1134. Thanks! http://dirtdevil.com/file/235/
Aug 30, 2014 | Dirt Devil Pd20000 Easy Steam Mop
Red devil steam mop not steaming
Check that plastic tube is not blocked or disconnected. Always use filtered water in tank.
Oct 25, 2013 | Dirt Devil Pd20000 Easy Steam Mop
How to disassemble Shark Mop s3601? I took all
You need to remove the shark and power button sticklers. There is two screws in each. Once you remove the screws you slide the grey cover and remove 3 more screws holding the chrome piece. Now you can spread the cover open. I just replaced a torn hose.
Oct 10, 2013 | Shark Euro-Pro Professional Steam Pocket...
Shark steam mop troubleshooting
This is a bad sign. The heating element has either come loose or the thermostat has failed to shut the heater down. Dont use it anymore. You can disassemble it and see what the damage is but the smell leads me to believe that it is damaged to the point that is should be replaced. Check the warranty to see if it is covered.
May 17, 2013 | Shark Euro-Pro Professional Steam Pocket...
How do i take the Shark S3601 apart?
Water is spilling from the hook upconnection to the carpet slider.
Solution: It needs to replace an O ring in the junction.
Question is: How do I remove the junction?
Dec 30, 2012 | Shark S3601 PROFESSIONAL STEAM MOP
Dirt Devil Pd20000 Easy Steam Mop Logo
29 people viewed this question
Top Dirt Devil Air Purifiers Experts
Vernon Taylor
stormlover
stormlover
Level 1 Expert
Tom Chichester
Are you a Dirt Devil Air Purifier Expert? Answer questions, earn points and help others
