Question about True TSSU7224MBST efrigerator
Hotpoint fufl 1810 fridge freezer runs for long periods is this normal ?
Hotpoint FUFL 1810 G Heater element always on, What can be a problem guys? Any idea? Anyone met with this problem before?
It is impossible to say, since you did not specify the MAKE or MODEL of your refrigerator.
If it is an older refrigerator, it is possible that your defrost timer has become stuck in "defrost" mode.
May 11, 2015 | Refrigerators
Hotpoint fridge freezer mod no fufl 1810 not working properly .food in fridge warm and freezer food starting to defrost. Have to turn on and off at plug before it kicks in again.... Any ideas
I have the samo model with same problem!
Try to do defrosting 24 hours! You can remove the back cover of freezer (inside) and check is there ice on the evaporator (looks like a radiator) If ice is there you can defrost by hair dryer!
Check after, should be ok, but I have a bad news! You have defrost system problem like me.
Mar 15, 2015 | Hotpoint Refrigerators
I have a hotpoint fridge freezer FUFL 1810, there is a puddle of water appearing on the kitchen floor coming from underneath the unit any help please ?
its the evaporator try its mounted above the compressor
perhaps the freezer has quick defrosted and the try is too full
use a towel and soak all the water off
check the freezer balast fan is running ok and fast enough {good speed}
or the freezer can reach a state where it just melts a little of the ice monster
so
my adivce is the run your food in it down
then completely defrost it
and you need to clean all the pipes that go too the evaporator tray
and then dress them with salt
they are usually at the bottom of the V shaped channels both at the back of the fridge
and also behind the freezer rear wall
it usualy has a panel with a few screws or pop plastic pins
that allows you too get too the blast fan and the evapoator V shaped channel
that guides the water to the evaporator pipe
so it prob needs something done with the frost free unit
i think its just got too the point its gummed up
with ice and the fan isnt working efficently anymore
Jan 10, 2015 | Hotpoint Refrigerators
I have a Hotpoint iced diamon fridge freezer, given to me second hand by a friend, no manual. Can anyone tell me what the two or three lights at the top mean with a picture of one droplet to the right of...
the drip ledge is for the drain hole in the middle which should be cleaned periodically.it is fitted for the condensation from the fridge to drain away.the "droplets"are ice crystals and one droplet is normal running,two us for fast freeze(when you have just filled/started from warm)the lights are "on and running"......fast freeze.......and overheat warning.as far as level 3 is concerned,get a frezzer thermometer and run the freezer at -18C and the fridge at +3C to 5C.,as it will change depending on the weather/kitchen temperature.(summer and winter).
Nov 10, 2010 | Refrigerators
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Will my mothers new fridge freezer work out in the garage
This is from the hotpoint web site.
If the room temperature drops below 14°C for an
extended period of time, the ideal temperature will not
be reached in the freezer compartment and food
preservation will be reduced.
You can read the manual here if it will help you.
http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19504293107_UK.pdf
Good Luck
Jan 11, 2009 | Hotpoint Refrigerators
Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Jul 18, 2008 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
True TSSU7224MBST efrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
