Question about Homelite Mighty Lite Blowervac
Homelite blow vac hbl26bv wont start - Homelite Mighty Lite Blowervac
Blower Vac HBL26BVN. The plastic primmer button has split. I cannot get a relacement. Help
Try this link:
http://www.ereplacementparts.com/homelite-ut08544-vac-attack-parts-c-18807_18808_139650.html
Jun 18, 2014 | Homelite Leaf Vac Attack
Electric homelite ut42120 leaf blower not blowing as strong
check the bottom of the unit for any obstruction. make sure the fan on the bottom is clean also
Jun 01, 2014 | Homelite 220 mph 300 CFM Electric...
I have run my Homelite Vac Attack ii using gasoline only. Now it wont run.
You need to take to shop and have them check it out, more than likely the cost of Repairs will exceed the price of a new Blower, In other words Yes this Motor is NO GOOD . Sorry For the Bad News..
Oct 23, 2011 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
Mar 11, 2010 | Homelite Consumer Products Backpack...
My vac wont start, there seems to be a problem with the choke not opening up properly, the spring seems to be broken?
You may have sucked some rubbish into the carb which is stopping the choke from opening properly, try taking the air filter off and having a look inside the carb to see if there is anything in there.
Nov 26, 2009 | Homelite Leaf Vac Attack
Will not start
Homelite leaf blowers that use whats called a half crankshaft system are prone to many problems. Whats a half crank system you ask? If there is a small aluminum plate that attaches to the side of the engine by the gas tank you have one of these. Usually held on with 4 small bolts. I just got rid of a Homelite Vac Attack 2 that had spark and compression but the compression checked low about 75 should be 90 or better. What happened, a head bolt came loose and the engine ran lean causing the fragile rings on the piston to heat up and when that happens they loose their outward spring that seals against the cyclinder walls. A simple compression check using a gauge and not your finger will tell you that. Other causes could be less than normal spark, or maybe the exhaust port under the muffler has carbon build up or the muffler is plugged up also Check all bolts, and nuts to make sure they are tight.
Glenn
St. Paul, MN
Apr 15, 2009 | Homelite Consumer Products MightyLite...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite Mighty Lite Blowervac Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
