Question about Troy-Bilt Pony Garden Tiller
Tb146 ec how do you replace the flex shaft on a troy-bilt tb146 ec tiller
  • 97 Answers
SOURCE: How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Posted on Mar 21, 2009
SOURCE: tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Posted on May 20, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
al_kupchella
  • 843 Answers
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Jun 15, 2010
  • 760 Answers
SOURCE: gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Posted on Jul 19, 2010
Removing motor from body and blades to change a starter rope?
unscrew cover where recoil rope is and cover and recoiler come off dont have to remove anything else
Aug 02, 2016 | Troy-Bilt TB146 EC 4-Cycle Garden...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replace pull cord
Easy to do - go to Utube and they have the instructional video on how to accomplish this. Hardest thing is to get the cord - Home depot only sells it in 50 foot lengths. But you can get a kit complete with handle for about five bucks same store.
Aug 31, 2015 | Troy-Bilt TB146 EC 4-Cycle Garden...
Warm up time on a Troy-Bilt cultivator
I have a Cub Cadet 4-cycle cultivator and it takes a while to warm up as well. I assume that is the norm for those small 4-cycle engines. But it should not take more than 3-5 minutes to warm up enough to go ahead and start tilling. Unless of course you live in a fairly cool climate. In that case it may take a little longer. I live in Tennessee.
May 09, 2015 | Troy-Bilt TB146 EC 4-Cycle Garden...
Rope pulls but does not trun motor
Recoil may be broken or seized up inside so it won`t work.
I had a lawn mower like that and tore the recoil off and had to repair the flippers inside. Mine had a broken pin.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Which fuel line is the intake line at the carburetor?
The fuel line goes:
  1. From the filter in the tank to the carb, usually the bottom most connector.
  2. From the carb to the Primer. The tube in the center of the primer bulb.
  3. From the primer, outer tube to the fuel tank.
Get the manual online from Troy-bilt herehttp://www.troybilt.com/equipment/troybilt/tb146-ec-4-cycle-garden-cultivator
j
May 07, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
How to replace gas lines on the tb146ec cultivator.
Hi Robert:
Sounds like a matter of removing the old lines and installing new ones.
Work safe! Drain fuel from tank first.
May 03, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Tiller culivator just sits and digs doesnt move forward? how do I resolve this?
Push down a little on the handle so the tines are not as far in the ground and also push forward a little.
Apr 10, 2013 | Troy-Bilt TB146 EC 4-Cycle Garden...
Need an operator's manual for a tb146 ec tiller
I believe that the tb146 ec is a Troy-bilt tiller, so you need the model number and the serial number to get the manual. Go to http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Then enter the model and serial numbers and click Search.
The plaque with these numbers is usually on the outside of the tine housing. It's generally in a spot that won't get damaged while the unit is in use.
I hope this helps.
Jul 08, 2011 | Garden
Troy-Bilt Pony Garden Tiller Logo
44 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
